Activity › Forums › Adobe After Effects › AFTER EFFECTS ERROR: Could not create 2200 x 2200 image buffer
  • AFTER EFFECTS ERROR: Could not create 2200 x 2200 image buffer
    Posted by Michael Zoppo on April 18, 2007 at 3:12 am
    When i want to render or view a piece of my composition, it wont render or let me preview it because it sais it can no create a 2200 x 2200 image buffer (size of a few solids i have in 3d space) what can i do to fix this?
    Aharon Rabinowitz replied 19 years, 5 months ago 3 Members · 2 Replies
  • Empathetic1636
    April 18, 2007 at 5:00 am
    I ran into the same problem a couple of weeks ago, with a canvas size of 8700X5333. Evidently, its a lack of memory that causes the problem. Some tricks you can do that worked for me is:
    Edit/Purge
    Lower your Redo count.
    Have no other programs running while you are in After effects.
    Check your Memory/Cache info in Preferences
    Crop the images in Photoshop so they are smaller in After Effects (In my case I was able to crop the image into say 4 chunks, that way I was able to keep the quality and lower the canvas size)
  • Aharon Rabinowitz
    April 18, 2007 at 6:30 am
    yes – this is a RAM issue. All of the advice given is good. Also working at 50% and half res, will help while working, but may be a problem while rendering. Make sure to set up AE to purge your RAM cache when you render or you will run into problems there too.
    You set that up in the secret menu – here’s a link to a tutorial that explains how to do that:
    Click Me!
    At least, I think that’s the tutorial. I’m pretty jet lagged at the moment, but I think that’s it.
    Aharon Rabinowitz
    arabinowitz(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Click the link below to subscribe to the Creative Cow After Effects Podcast, and get free AE video tutorials:
    https://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=111087911
