Activity Forums Adobe After Effects After Effects error: CINEMA 4D: Render Failed
  • After Effects error: CINEMA 4D: Render Failed
    Posted by Blessed Faith mwende on July 9, 2019 at 5:34 am
     Hi everyone! I’m Faith.
    It’s my first time working with AE cinema 4D, I get the error (****AEGP plugin Cinema 4D: CINERENDER – connection failure****)
    Then
    (****After Effects error: CINEMA 4D: Render Failed****) when i create new project. It’s when i use Cinema 4D render engine inside of AE.
    I’ve tried all this, still not working
    * TCP Port change
    * Purging cache
    * formatted pc
    * upgraded AE
    * not sure about Firewall settings but added After Effects CC 2019 recently
    * running After Effects as Admin
    I don’t know if I’m missing a plugin or something.
    I don’t have Cinema 4d installed.
    I’m using Adobe After Effects CC 2019
    Windows 10 1903
    Please, Would love if anyone have insights that would help. I’ll be grateful to you!!
    God bless you all.
    Oleg Pirogov replied 6 years, 9 months ago 3 Members · 3 Replies
  • Chris Scalzo
    November 15, 2019 at 7:01 pm
    I have the same problem. I believe here it has something to do with network permissions or network firewalls (because I am behind corporate walls). It is quite frustrating since I can’t really use Cinema 4d renderer for extrusions and often find myself faking them in classic 3d in styles circa 20 years ago.
  • Oleg Pirogov
    November 15, 2019 at 8:17 pm
    One more thing to try: change port 5030 to 5027 in Cinema 4D render properties. That worked for me.
  • Oleg Pirogov
    November 15, 2019 at 8:21 pm
    *not sure what you meant by “TCP Port change” – that or smth else.
