Activity Forums Adobe After Effects AFter Effects error: Can’t overwrite file
  • AFter Effects error: Can’t overwrite file
    Posted by Joey Sperber on March 17, 2014 at 1:27 am
    Hi, I recently updated to a mac pro and used my backups from my old computer to put on the new one. Now whenever I open up a old AE file or try to use dynamic link with Premiere Pro I get the message
    After Effects error: Can’t Overwrite file “/Users/joey/Library/Preferences/Adobe/After Effects/11.0/Adobe After Effects 11.0-x64 Prefs
    The problem is that I can’t even find that file on my hard drive, any idea what happened
    Joey
    Ot Crozz replied 10 years, 1 month ago 7 Members · 6 Replies
  • Roland R. kahlenberg
    March 17, 2014 at 5:13 pm
    No idea what the issue is but you can find the Prefs File via AE’s Preferences dialog window. In this window, at the bottom left, is a button that sends you to the OS and selects the Prefs file.
    HTH
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Walter Soyka
    March 17, 2014 at 7:05 pm
    Mac OS now hides your Library folder. Here are 19 different ways to get to that folder on Lion and up:
    https://www.macworld.com/article/1161156/view_library_folder_in_lion.html
    Easiest way: go to Finder, press Cmd+Shift+G (for Go to Folder) and enter:
    ~/Library/Preferences/Adobe/After Effects/
    Select the 11.0 folder and press Cmd+I (for Get Info). You may need to click the lock button in the lower right corner and enter your password to allow yourself to make changes. Make sure that the folder is set “Read & write” and also click the gear button and choose “Apply to enclosed items.”
    Walter Soyka
  • Todd Kopriva
    March 17, 2014 at 11:14 pm
    For details about what’s going wrong here, see the last section of this article:
    https://blogs.adobe.com/aftereffects/2014/01/known-issues-workarounds-after-effects-cc-12-2.html
    After Effects team blog
  • Daniel Ziegler
    July 14, 2014 at 5:42 pm
    Walter – Thanks so much. You just saved my A. BTW, it works for AE 10.0 as well.
  • Henry Lee
    May 18, 2015 at 12:37 pm
    Yes! Your read/write issue solved mine too! Thanks.
  • Ot Crozz
    March 26, 2016 at 12:37 am
    WOW! Thank you for your post. I had the same issue(s).
    Jack of all trades – Want to master them ALL. Yup you guessed it… I’m a pre-press artist.
