Activity Forums Adobe After Effects After Effects Error: Bad Tracked Memory ID
  • After Effects Error: Bad Tracked Memory ID
    Posted by Randy Burleson on September 27, 2010 at 4:08 pm
    I am getting this AE error: After Effects Error: Bad Tracked Memory ID (23::34)
    Does anyone know what this means or how to fix the problem?
    It keeps crashing AE and I am not sure what to do to fix this.
    AE CS4
    Mac OS 10.6.4
    Luke Milton replied 13 years, 2 months ago 4 Members · 4 Replies
  • Michael Szalapski
    September 27, 2010 at 7:21 pm
    From Mylenium’s AE Error Code Database:
    Message interpretation:
    An internal allocation process resulted in a faulty request for memory from an area not currently controlled by After Effects.
    Possible causes:
    Seems to be related to handling compressed media. CoDecs may use fixed memory areas to store there compression algorithms which may then end up outside the reach of the host program.
    What sort of video files are you using? You might try converting them to lossless Quicktime or AVI files.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Soheil Sigurd
    October 6, 2010 at 8:45 am
    Hello,
    I keep getting “Bad Tracked Memory ID” error. I am woring in CS4 Mac. And the project is only using taga files.
    Any solutions? I need to finish this project and I cant do anything because I keep getting th error and crash.
    Can anybody help? Pleaese.
  • Michael Szalapski
    October 6, 2010 at 9:47 pm
    The After Effects 9.0.3 update fixes some memory issues. Try it and see if it helps.
    – The Great Szalam
  • Luke Milton
    June 5, 2013 at 2:54 pm
    Did you get a solution for this? – I am getting the same error and I can’t edit my work.
    Luke
