Activity › Forums › Adobe After Effects › after effects error: an output module stopped responding.
Posted by Ericsson Chu on August 15, 2010 at 9:19 pmHello, I have been trying to export a project I’ve been working on, but it seems to continually give me back an error (after effects error: an output module stopped responding…). In the end it always creates a few seconds long clip, that is about 1 gig in size. I have been able to export it out before, so I am not sure exactly what has changed? I am trying to export in animation codec with audio.
Lachlan Fletcher replied 13 years, 10 months ago 5 Members · 6 Replies -
David Johnson
August 16, 2010 at 1:01 amHave you tried using the render queue instead of exporting?
If that doesn’t solve the issue, more detail will be needed for anyone to help since there could be issues in any one of many places such AE settings (is OpenGL off?), RAM (do you have enough?), other machine specs (can you’re machine handle the render you’re trying to do?), codecs (are you working with some wonky codec?), etc., etc., etc.
Ericsson Chu
August 16, 2010 at 10:46 amhello, thanks for the reply.
i am running on a macbook pro santa rosa 2.4 ghz with 4 gb of ram… adobe after effects cs5. I am trying to output to animation codec using the render queue. The projct rendered fine on the same machine previously (albeit the project was smaller). After effects gives me the error a about 6 seconds in for the animation codec file, and 12 seconds for a prores file I tried (by 6 and 12 seconds I mean that it manage to export a watchable clip that is that long… it actually is running for a couple of hours).
I am now trying animation codec with open gl and no audio.
oh the end of that error says something about something possibly being corrupted and to try restarting after effcts? I should’ve wroten the full sentence down, alas i’ll try again overnight and if it doesn’t work again i will!
Ericsson Chu
August 16, 2010 at 5:10 pmhmm, it seems with open gl on it renders 25 seconds with black box glitches… its supposed to be one minute, but no error box comes up. any thoughts?
Chris Liddell
December 8, 2010 at 12:47 amI am having the same issue with my 2x 2.66 DualCore Mac Pro / 6GB RAM / ProRes 422 or 4444 codec… MultiProcessing turned off
any more light to shed please?
thanks
C -
Cameron Zoch
April 18, 2012 at 3:02 amI just had the same error. I have been rendering a project for the past 44 hours and had 2 hours left. Just checked the progress and it had crashed with this error.
Computer Specs:
-Dell XPS L502X
-Windows 7 Home Premium
-Processor: Intel Core i7-2630QM
-CPU: 2.00GHz
-Ram: 8.00GB (7.90GB Usable)
-64bit
I had memory & multiprocessing on, All CPU’s and RAM given to AE. I did not however, have OpenGL on.
Please advise me on what to do because I have never rendered this big of a project before. -
Lachlan Fletcher
November 5, 2012 at 9:34 pm
