Activity Forums Adobe After Effects After Effects error
  • Jason Demek
    June 18, 2008 at 4:29 am
    Try playing around with your memory & cache preferences. Raising your maximum memory usage or lower your image cache preferences, it helps reduce fragmentation. I’m running a Macbook Pro with 4 GB ram. I’m able to create a project at 2500 x 1500. My maximum memory is set at 120% or 3 CB. Maximum RAM cache size is set at 60% or 1.8 GB. Hope this helps.
    Jason Demek
    Editor/Animator/Director
    CW21 – Birmingham, AL
  • Peter Van der zee
    June 18, 2008 at 10:46 am
    And ‘purge all’ before render (edit menu)
    and if it’s a long render you might like to purge memory every xx frames
    (secret settings in preferences, shift click preferences)
    http://www.zeemotion.com
