Activity › Forums › Adobe After Effects › After Effects error (44::36)
Posted by Seyfi Cem baskın on April 3, 2008 at 7:04 amHello there. I’m trying to export as quicktime and i get this error with all quicktime codecs&settings :
After Effects error: creating movie – bad parameter (-50).
(44::36)Using Quicktime Pro 7.4.1 and AE CS3, but i think it does not depend on versions. Anyone knows what causes this? Any help will do great, thanks.
Cem
Dimitris Stefanis replied 14 years, 10 months ago 6 Members · 7 Replies -
Steve Roberts
April 3, 2008 at 2:36 pmGoogling the error led to this page on Mylenium’s site:
https://www.mylenium.de/creation/motiondesign/ae_errors/ae_errors_31-40.html
Since the number and message don’t match, you may need to look around the site. Hope it helps.
Seyfi Cem baskın
April 3, 2008 at 2:45 pmWell, i have reached the same site just half an hour ago, couldn’t find though 🙂 There is a huge chance that it may be Quicktime’s problem.
Cem
Maciej Szudarek
June 13, 2009 at 9:21 pmI was having the same problem all the time and finally I’ve found the solution. You simply CAN NOT use any of these letters typical for particular countries (like ś, ź, ż, ę, ó, ń etc.) in the name of file neither in the render directory. So just change the name of file and the render directory if needed and everything should be fine. :>
Hope it will work,
Nextion24 -
Seyfi Cem baskın
July 1, 2010 at 12:21 pmYeah, that worked. A year ago 🙂
So I hereby thank you roughly after one year.Cem
Jared Isham
October 5, 2010 at 7:13 amI had an issue with this error as well but I don’t think it was a QT error. I was running the cartoon effect in AE CS4, it didn’t start giving me this error until I reached the final 3 shots for my client. The only way I could get it to export was by turning the cartoon filter off. I played with the advanced settings and turning OpenGL on and off but with no success.
I’m gonna trouble shoot it some more after I deliver all my files.
Jared Isham
Stage Ham
https://www.stgham.com
film. video. web media -
Dimitris Stefanis
October 28, 2011 at 9:34 amI had the same problem with AE cs4. I tried everything and I found that I can export the movie from the file menu file-export-quick time movie and it worked perfectly
