Activity Forums Adobe After Effects after effects error
  • after effects error
    Posted by Paapoopa on July 13, 2006 at 10:58 am
    Have anyone encounter (“After Effects warning: Unspecified drawing error.”) ?
    I am using after effects 7.0 running on PC win xp
    this error is poping out every 5 mins and its drving me nuts.
    Xavier De champs replied 20 years, 1 month ago 4 Members · 3 Replies
  • Dino Muhic
    July 14, 2006 at 5:22 pm
    How about re-installing After Effects? I never had such an error.
    Does it happen no matter what you are working on in AE or just on special effects or comps? Perhaps try using adaptive resolution or in this cae perhaps OpenGL?
    just my 2 centss
  • Jkstudios
    July 29, 2006 at 1:33 pm
    I have this error aswell.
    It occurs upon rendering, whereby the comp flashes to black when rendering frames…and for each unrendered frame it displays this dialog box (sometimes hundreds of times).
    It seems to occur when the AE renderer gets to 55% of RAM on my pc, as stated in the render info panel.
    I have 2 Gbs of ram and a high spec machine, and the comp im working on is not mind bogglingly huge,but it is dealing with large files…I require to render out movie, uncompressed, which works out to 2Gb…It has worked before and managed to render this once after being very picky….but now its back up to its old tricks and im unable to work with it it seems.
    Im wondering if anybody has the answer or any advice…is this an AE fault a RAM fault, or something else?
    Many thanks.
  • Xavier De champs
    August 23, 2006 at 9:08 pm
    I found a fix on another forum for this error.
    It has something to do with AE not being able to handle RAM cache of some kind. Well…you can shut it off. But you actually don
