Activity Forums Adobe After Effects After Effects Error
  • After Effects Error
    Posted by Rich Stahle on April 6, 2006 at 10:18 pm
    I’m making a moving video wall – there is a wall of imported video, 6 wide by 12 deep, imported video is standard avi 720×480 files, my video wall length is 30 sec. I am using animated cameras to move the wall about.
    The video wall composition size is 1860 x 2473 which is then used in a standard DV composition 720×480 which contains the animated cameras & movement etc.
    When I render with all the video in the video wall disabled my composition renders fine with all effects & text etc that is also added.
    When I try to render with the video . . . . I always get the following error:
    After Effects error: retrieving frame from video stream. (3) (53::34)
    What causes this? how to I stop it? the files are there and accessible….any ideas?
    Underground Video Television
    UVTV Productions
    Damaged Goods
    Rich Stahle replied 20 years, 5 months ago 7,869 Members · 1 Reply
  • Rich Stahle
    April 7, 2006 at 3:42 am
    nope not that.
    it appears it is something about a codec /material rendered by vegas according to info I found on After Effects website.
    I’m going to render portions of what I want to quicktime files and assemble them.
    AE can find everything ok – but randomly gives errors due to a bit set by Vegas when it renders AVI files to signal they can be larger tahn 2gb.
    UVTV Productions
    Damaged Goods
