Activity Forums Adobe After Effects After Effects Error 17::18: zero denominator converting ratio denominators
  • After Effects Error 17::18: zero denominator converting ratio denominators
    Posted by Maria Kahn on October 23, 2011 at 7:00 pm
    I copied the Project with the error into a new Project window & deleted each layer in order to see which layer carried the glitch. I noted that when I deleted the video footage layer that was imported from FCP as a QT movie, the error message disappeared.
    Obviously a glitch somehow has developed in the footage settings I assume.
    I right clicked on the footage, went to Interpret Footage > Main & noted the frame rate is at 0.01. The frame rate I have have used in all my Compositions has been 29.97. I changed it to 29.97, but it does not change it and the error message continues to appear.
    Someone PLEASE HELP
    Karel Van gelder replied 14 years, 9 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    October 25, 2011 at 11:45 am
    Looks like a corrupted file and you’ve got to head back to the source and regurgitate another version.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia – Adobe ACE/ACI (version 7) & Mocha Approved Trainer – Imagineer Systems Inc
  • Karel Van gelder
    November 18, 2011 at 2:50 pm
    I had the same problem when I re-opened an old Afx Project.
    Afx linked to a non self contained reference file from FCP.
    In the meanwhile I had consolidated the FCP project (media manager) and deleted the old footage from the disk.
    The problem was that the reference file linked to footage that didn’t exist anymore.
    I exported a new reference file from the consolidated FCP project and replaced the old reference file.
    Then I reopened Afx, problem solved.
    So for short:
    I replaced a reference file that linked to non-existing footage.
    I hope this is any help to your problem.
    Karel
