Activity › Forums › Adobe After Effects › After Effects Ease Expression Question
  • After Effects Ease Expression Question
    Posted by John Winthrop on July 22, 2016 at 2:05 pm
    Hello, I am brand new to using expressions and I have googled and looked at tutorials to try to figure something out but my question is specific.
    I have an expression on a tree to make it sort of bounce up and down from its anchor at the bottom.
    ———–(On the SCALE property under transform)
    amp = 20;
    freq = .25;
    y = amp*Math.sin(time*freq*Math.PI*2);
    value + [0,y,0]
    This expression was originally used for a bob effect under the POSITION property and i copied and pasted it to SCALE of the tree, worked like a charm.
    I want to make the bounce effect of the tree Have a different EASE value so it still moves the same speed in between but sort of stay at the top and bottom longer.
    I used this expression on an object to make it sway back and forth on the ROTATION property.
    swingMaxDistance = 75;
    swingSpeed = 5;
    easeTimeSpan = 6;
    easeSpeed = 1;
    easeVal = ease(time*easeSpeed, 0, easeTimeSpan, swingMaxDistance, 0);
    Math.sin(time*swingSpeed) * easeVal;
    Copying the ease expressions from this into my SCALE property on the tree did not work because the coding seems to be different. I tried changing “swingMaxDistance” to “scale Y” and that didn’t work either. I am in a bit over my head here.
    How would I go about writing an expression in my SCALE expression (at the top of the page) so that I could have the “easeTimeSpan” “easeSpeed” “easeVal” applied to the scale keyframes?
    Thank you in advance.
    John Cuevas replied 10 years, 2 months ago 2 Members · 1 Reply
  • John Cuevas
    July 22, 2016 at 2:53 pm
    MIght want to try the Expressions Forum.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
