Activity Forums Adobe After Effects After Effects doesn’t recognize .vpe as an acceptable file to import
  • After Effects doesn’t recognize .vpe as an acceptable file to import
    Posted by William Armistead on April 9, 2013 at 5:42 pm
    Hey all,
    I’m trying to create a camera move down a prison hallway from a Shutterstock image. I created the vanishing point data in Photoshop CS 5.5 (I dragged each plane from the previous plane so as to maintain 1 vanishing point) and exported for after effects.
    The PNGs are where I saved everything as well as the .vpe file and .3ds file.
    When I go to import into After Effects (CS 5.5) the .vpe file is grayed out. Selecting all files leaves me wondering which format to use.
    I imported this successfully once before but was unhappy with the distances, as I had created my vanishing point data from the original image size (the camera needed to move over 100,000 pixels to traverse the hallway).
    The only thing I’ve really done differently is resize the image to 1280×720(comp size) and created a few more planes to represent the second tier of cells jutting out over the 1st.
    Is it possible I need to keep it to 6 planes or fewer?
    lesarmistead@gmail.com
    https://www.wix.com/Rotenbard/version-2
    William Armistead replied 13 years, 5 months ago 2 Members · 2 Replies
  • Todd Kopriva
    April 9, 2013 at 9:36 pm
    How, exactly, are you trying to import the .vpe file? I.e., what is the exact menu command that you’re trying to use?
    After Effects team blog
  • William Armistead
    April 10, 2013 at 1:56 pm
    Doh! I was using the straight File>Import. Went back in and realized I should be using File>Import Vanishing Point(.vpe)
    Thanks Todd, for helping with my obvious brain fart.
