Activity › Forums › Adobe After Effects › After Effects Custom Output Suffix
  • After Effects Custom Output Suffix
    Posted by Chris Meadmore on August 28, 2020 at 9:43 am
    I’ve not played with this function before but inside of AE render you can select ‘output to / custom’ and add a suffix based on lots of values.
    Is there anyway to link it to a layer name or drop down menu effect within a comp?
    I’ve built a toolkit with language drop down to control fonts and translation; EN, FR, AR etc etc.
    What I really want is for the file name to add a suffix based on the language so it would read the drop down effect. Is that possible?
    Chris Meadmore replied 6 years ago 1 Member · 0 Replies
  • 0 Replies
