Activity › Forums › Adobe After Effects › After Effects CS6 user reporting slow render times, reboot fixes problem
  • After Effects CS6 user reporting slow render times, reboot fixes problem
    Posted by Brian Brunning on September 12, 2012 at 6:06 pm
    I have an artist running AE CS6 on a new dual 12-core Mac Pro with 16GB of RAM. She is complaining that she needs more RAM to get rid of some problems with her computer rendering & RAM Previewing and slowing down constantly. I’ve set AE to only use 6 CPUs with Multiprocessing and leaving 4GB of RAM for other apps.
    She claims it’s all because she needs 32GB of RAM but I’m seeing more and more similar problems where a reboot fixes the problem and the renders/RAM Previews run quickly again.
    Anyone having similar problems and know a resolution?
    Thanks in advance
    Darby Edelen replied 14 years ago 3 Members · 4 Replies
  • Darby Edelen
    September 12, 2012 at 7:05 pm
    I’ve experienced issues like this for RAM intensive renders. I’d suggest a few potential solutions, a combination of these might help:
    1. Reduce the number of processors available to AE.
    2. Increase the available space on your system drive.
    3. Buy more RAM.
    Darby Edelen
  • Joseph W. bourke
    September 12, 2012 at 7:07 pm
    Hi Bryan –
    I’m a PC guy, but I think you might find the contents of this page most enlightening – at least they should lead you to a solution:
    https://macperformanceguide.com/Optimizing-AfterEffects.html
    While 32GB of RAM should most certainly improve your speed, the fact that a reboot speeds things up leads me to believe there’s something else going on. Good luck!
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Brian Brunning
    September 12, 2012 at 9:01 pm
    There’s enough space on the system and we have limited the processors. The main culprit seems to be Keylight, it has major memory leak issues. I was unaware she was using that. Anyone know a fix for the keylight mem leaks?
  • Darby Edelen
    September 13, 2012 at 8:07 am
    I haven’t experienced issues with keylight personally.
    If you disable multiprocessing and make sure that at least 32 GB is available on the system drive, does that help the issue?
    Darby Edelen
