Activity › Forums › Adobe After Effects › After Effects CS6 Shows Nothing but Blackness!!
  • After Effects CS6 Shows Nothing but Blackness!!
    Posted by Josh Pulido on April 18, 2014 at 7:29 pm
    My Adobe After Effects Project was going smooth, until i decided to render it out, then got a long error, so i was gonna go back and render it out in chunks, but then everything in my composition window went black, i scroll through the composition, and nothing comes out.. Please help This project is due soon thanks!
    -Josh Pulido
    Josh Pulido replied 12 years, 5 months ago 3 Members · 3 Replies
  • John Cuevas
    April 18, 2014 at 7:36 pm
    Start by purging the cache (Edit > Purge).
    If that does’t help, post a screen grab of your timeline and comp window.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Chris Brett
    April 19, 2014 at 11:31 am
    Hi Josh
    —————- this has happened to me also — the black is no problem the comp is still there —- just clear all the cache areas and reboot the machine — should load normally and off you go…
    — seems to me that memory areas are not automatically cleared and fill up causing problems …..
    I clear as below – its probably a bit ‘belt-and-braces’ but seems to work for me……
    edit / purge / / all memory plus image cache memory
    also
    edit / preferences / media and disk cach / empty disk cache plus clean database and cache
    Then exit AE and reboot the machine.
    Editing in sections has worked for me when I’ve had real problems in the past — just render as sequential files till it crashes / delete last rendered frame in case corrupt / then re-render from that frame number straight into same folder till it crashes again or finishes etc — its a pain but no real problem …
    ————————————- chris —
  • Josh Pulido
    April 19, 2014 at 1:28 pm
    Alright it worked thank you:)
