Activity › Forums › Adobe After Effects › After Effects CS6 RAM previewing slower than normal?
  • After Effects CS6 RAM previewing slower than normal?
    Posted by Greg Wolff on February 4, 2014 at 1:51 am
    Usually I can get a pretty quick preview-render/ram-preview on After Effects but every now and then, seemingly in the most important moments, the program seems to ram preview very slow at ANY RESOLTUION/QUALITY. It will render as slow as it does at 10% quarter quality as it does at 100% full quality.
    Some quick specs:
    Intel Core i5-2300 CPU @ 2.80GHZ
    8.00 GB RAM
    64 bit Windows 7
    AMD Radeon HD 7870
    Thanks for the help. Any suggestions will be appreciated.
    Roland R. kahlenberg replied 12 years, 7 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    February 5, 2014 at 1:39 am
    Check to see if you have Render Multiple Frames Simultaneously selected in Edit>Prefs>Memory & Multiprocessing. With RMFS, it may take some time to initialize multiple cores prior to a RAM preview.
    With CS6 and CC, you really need to get to know your setup really well. RMFS, on certain types of footage/layer/comps, RMFS can be slow. In CC, there is a setting to initiate RMFS only for final renders and not for previews.
    Cheers
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
