Activity Forums Adobe After Effects After Effects CS6 Keylight Mask issues
  • After Effects CS6 Keylight Mask issues
    Posted by Fred Raimondi on July 22, 2012 at 12:35 am
    I’ve noticed a bug (at least I think it’s a bug) when you use Keylight 1.2v14 and an animated mask.
    Basically what I was doing was taking a blue screen element and getting rid of all the extra garbage in the
    frame using shape layers and masks. When I take that layer, move it into a comp and then key it with Keylight 1.2v14 parts of the frame seem to drop out. Not the whole frame, certain areas.
    https://skitch.com/fredfx/eedfd/keylight-after-effects-artifacts
    Any ideas? Is there a fix or workaround without precomposing?
    I also noticed that when using the “inside mask” in Keylight I get a different kind of artifacting where the whole image disappears what seems randomly but I believe is related to masking also.
    Fred
    Model Name: Mac Pro
    Model Identifier: MacPro3,1
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 3.2 GHz
    Number of Processors: 2
    Total Number of Cores: 8
    L2 Cache (per Processor): 12 MB
    Memory: 20 GB
    Bus Speed: 1.6 GHz
    Boot ROM Version: MP31.006C.B05
    SMC Version (system): 1.25f4
    NVIDIA GeForce 8800 GT
    “Establish the possible, and move gradually towards the impossible”
    -Robert Fripp
    Jon Merrifield replied 14 years ago 3 Members · 4 Replies
  • Roland R. kahlenberg
    July 23, 2012 at 12:56 am
    What happens if you only use masks – ie do not use shape layers?
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Jon Merrifield
    September 20, 2012 at 7:54 pm
    Hi Fred,
    I am just posting since we know each other through Stu.
    I consider keylight buggy anyway. I use it to create mattes and fills separately and almost never use the final result inside of keylight since most of my work includes several custom mattes and masks to get the comp and keys to look their best. Much of my matte work and keying for that matter is outside of Keylight. I do use it to color correct my fills sometimes as well but often creating a perfect matte is a combination of mattes generated with keylight as well as other keyers and custom masks. Just sayin’,,,
    cheers,
    -Jon
    Jon Merrifield
    VFX Artist / Supervisor
    PELi Studios, Austin TX
  • Fred Raimondi
    September 20, 2012 at 8:41 pm
    Yeah…..nothing is perfect. The I’ve actually switched over to Primatte as my primary process screen keyer.
    I can’t remember the last time I pulled a key with no futzing……THere’s always SOMETHING to be masked…..I try to avoid the “cut and paste” fest whenever I can though…
    I can’t wait to do a project with you….
    Check out this film I just made for The California Guitar Trio
    https://vimeo.com/49527232
    best,
    Fred
    -Robert Fripp
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Jon Merrifield
    September 20, 2012 at 11:34 pm
    NICE!…
    Look forward to working with you as well.
    I’m juggling 3 projects at the moment. But please email me whenever you would like to catch up or the like.
    jon@pelistudio
    cheers,
    -Jon
    Jon Merrifield
