Activity › Forums › Adobe After Effects › After effects CS6 3D Camera Tracker
Josiah Wood replied 13 years, 9 months ago 5 Members · 28 Replies
Roland R. kahlenberg
May 12, 2012 at 4:22 pmTry the following –
1) Give 2GB or RAM per AE proc.
Given you have 12GB of RAM, you should set aside 4GB for other apps. You then have 8B left for AE. Therefore, you should set aside 4 procs for AE with each proc using 2GB of RAM.
Cheers
RoRKIntensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer -
Jean-pierre Michael
May 12, 2012 at 4:33 pmIf i use 2gb I can’t get 4 procs running, i have to use 1.5 wich I did.
And now AESelflink processes are 6 running at the same time without any more progress and I can’t even kill them if I don’t Kill AE first.
Very strange behaviour…
Thanks for trying to resolve my time consuming problem Roland -
May 13, 2012 at 2:49 amIf MP is off and yet there are multiple instances of AESelflink then perhaps your Prefs File is corrupted.
To delete the Prefs File and force AE to create a new one, press CMND+OPTION+SHIFT when AE is starting up.
HTH
Jean-pierre Michael
May 14, 2012 at 9:03 amMultiple instances appears only when MT is on. Or when I launch Warp and 3D at the same time. and never quitting.
I’m gonna let it go. It’s useless… -
May 14, 2012 at 11:45 pmHi JP, file a bug form here https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Good Luck
Jean-pierre Michael
May 15, 2012 at 12:03 pmThanks a lot Roland, I Wrote a note for them. We’ll see what happens..
Josiah Wood
December 11, 2012 at 6:48 amWow, thanks so much. I’ve been trying to figure this same issue out for days, and that was the problem. How on earth does popclip cause a problem like that in After Effects??
