Activity › Forums › Adobe After Effects › After Effects CS5.5 Ram Preview Issues
  • After Effects CS5.5 Ram Preview Issues
    Posted by Randy Rubin on March 21, 2012 at 3:52 pm
    I’m currently having issues with RAM preview in After Effects. It fails to render my entire workspace. I have a solid layer with a paint effect on it that has about 27 brush strokes, with their start/end keyframed. I try to render about 22 seconds worth and it only gets to about 14 seconds.
    This is a new issue that came up yesterday as well. It’s been happening when I duplicate layers into new comps or dup entire comps. This same thing happened when I was trying to render a comp with about 10 illustrator layers with only transform/mask keyframes.
    I’m working on an iMac 3.4 ghz i7 with 16gb of ram. My media cache is at 20gb. I have 3 GB ram reserved for other applications, 1 CPU reserved for other apps, 2GB allocated per bg cpu and 5 Actual CPUs being used.
    Any help much appreciated
    Walter Soyka replied 14 years, 6 months ago 2 Members · 3 Replies
  • Randy Rubin
    March 21, 2012 at 4:33 pm
    Thanks, I’ve reviewed this section – nothing really answers my question. I typically can RAM preview working spaces much longer than 14 seconds of the same material or the same material + 12 layers beneath it. If I missed something please let me know.
    Randy
  • Randy Rubin
    March 21, 2012 at 5:29 pm
    I think that just answered my question. I turned off multiple processing and was able to watch the entire length of the working space. I assume this solution is only recommended for comps that aren’t processor intensive.
    Would a RAM preview of a 3D comp with lights qualify as ‘processor intensive’?
    Randy
  • Walter Soyka
    March 21, 2012 at 6:54 pm
    [Dave LaRonde] “But since you reviewed the ways to preview, you’re aware that you can shorten the AE Work Area to preview smaller portions of the comp. I think I’d do that instead.”
    Or RAM preview at lower resolution, or RAM preview with skipped frames.
    Personally, I set up Shift-RAM preview at quarter or half res, skipping every other frame. I keep RAM preview at half or full res, every frame.
    Walter Soyka
