Activity › Forums › Apple OS X › After Effects CS5.5 on OSX Lion 10.7.1
  • After Effects CS5.5 on OSX Lion 10.7.1
    Posted by Martin Brazeau on August 30, 2011 at 8:29 am
    Hi there,
    Recently, I purchase the Adobe CS5.5 Production Premium which I have installed on my MacPro running OSX Lion. Everything seems to work fine except for the fact that I constantly have to authorize After Effects to accept incoming network traffic every time by getting the following message : “Do you want the application After Effects.app to accept incoming network connections?”. If I go in the firewall setting, After Effects is already set to accept incoming network traffic (active with a green dot) But it still ask for it every single time I launch it!
    I had a similar problem with itunes in the past which resolve by itself thru OSX updates.
    Hope someone have a solution because it is very annoying.
    Thank You,
    Martin B.
    Martin Brazeau replied 15 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
