Activity › Forums › Adobe After Effects › After Effects CS5.5 freezes on render in multiproccessing mode
  • After Effects CS5.5 freezes on render in multiproccessing mode
    Posted by Garret Layman on November 28, 2012 at 2:10 pm
    I get the beachball a few seconds after I click render on any comp in any project no matter how simple or complex if multiprocessing is turned on. I have used multiprocessing with no problems up until about a week ago and I can’t seem to resolve this with solutions from any other post. My initial settings were 10 gb of RAM and 4 cores allocated for other applications. I have raised both to well over 75% of my total capacity but still no improvement. This is really slowing down my workflow, any ideas would be greatly appreciated.
    Specs:
    Mac Pro 2010
    2 x 2.66 GHz 6-Core Intel Xeon
    64 GB RAM
    OSX Lion
    Garret
    Nicholas Toth replied 13 years, 10 months ago 2 Members · 3 Replies
  • Garret Layman
    November 28, 2012 at 3:55 pm
    That was my first inclination as well but I haven’t been able to think of or find anything that has changed, I haven’t run any updates or made any changes that I’m aware of.
    I was however able to get AE to render with Multiprocessing after allocating my RAM to 32 for AE and 32 for everything else.
    Any ideas why I would have a sudden decrease in the amount I can use?
    Mac Pro
    2×2.66 GHz 6-Core Intel
    64 GB 1333 MHz DDR3
    NVIDIA Quadro 4000 2048 MB
  • Garret Layman
    November 28, 2012 at 7:45 pm
    Thanks Dave.
    I appreciate the responses and the information. I guess at the very least we have something to look forward to, right? Let’s hope anyway.
    Mac Pro
    64 GB 1333 MHz DDR3
  • Nicholas Toth
    November 29, 2012 at 6:14 am
    We are running AFX5.5 in our shop, and needless to say the render engine can be a train wreck (along with frequently restarting because of memory leaks). However, this nifty script tends to manage hardware resources/priority and help a lot. We cut render times down roughly 20-50% depending on the job. Don’t run it in the background, run it in the foreground and have it ping all resources possible — but read up on what does what before you alter any settings.
    https://aescripts.com/bg-renderer/
    It renders through the terminal/command line — and has worked great for us. Its not an answer to your question but give the free version a shot, it might help.
