Activity Forums Adobe After Effects after effects cs5 sometimes crashes
  • after effects cs5 sometimes crashes
    Posted by Leo Lagerwall on July 23, 2010 at 2:35 pm
    Hi
    I am using ae cs5 under windows 7 , the program sometimes crashes when I am using many effects togheter…
    An example could be a big scene. A lot of adjusment layers, and
    pre-composed scenes, layers , color adjusted materials.
    It is really annoying because I dont get the chance to save the projects… Is this normal , or does a perfect system exist..?
    error code:
    Faulting application name: AfterFX.exe, version: 10.0.0.458, time stamp: 0x4bb2fd36
    Faulting module name: ntdll.dll, version: 6.1.7600.16385, time stamp: 0x4a5be02b
    Exception code: 0xc0000374
    Fault offset: 0x00000000000c6cd2
    Faulting process id: 0x758
    Faulting application start time: 0x01cb2a659888d300
    Faulting application path: C:\Program Files\Adobe\Adobe After Effects CS5\Support Files\AfterFX.exe
    Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
    Report Id: 0c3688c1-9665-11df-83b9-90e6ba0d3e1e
    Leo Lagerwall replied 16 years, 2 months ago 34,777 Members · 4 Replies
  • Leo Lagerwall
    July 23, 2010 at 4:23 pm
    My spec:
    ASUS P7P55D PRO, Intel P55 Express, 4DDR3 / 2PCI / 2PCIe x1 / 3PCIe x16 / 7SATA / 1IDE / 1eSATA, FireWire / 8USB / GBLAN / HD-Audio, ATX, LGA1156
    Intel CPU Intel Quad Core i7 860 (2.8GHz) Socket-1156 1333MHz 8MB Cache 64bit 95W Lynnfield B1 Boxed
    DDR3: 1 x Corsair XMS3 DDR3 1600MHz 4GB CL8
    Seagate Barracuda 7200.12 1TB x2
    Nivida engtx 275
    running under windows 7 64-bit. (latest drivers for everything)
  • Leo Lagerwall
    July 23, 2010 at 4:52 pm
    Thanks for the answer.
    What is strange is that it happens quite seldom , I can work with big scenes, but suddenly after an hour the ae crashes, sometimes I can work one day without any crash.
    But its really annoying when it happens…
  • Leo Lagerwall
    July 27, 2010 at 7:45 pm
    Thank you for caring.. But i never ran multiprocessing in AE… 🙁
    And I have allocated 2,5 gb ram.
    It is really annoying when the program just crashes with different kind of error messages, I am so tired ot this computer- build. I just want AE to work , I am thinking about selling this one and buy another computer as I cant take all the crashes…
  • Leo Lagerwall
    July 28, 2010 at 2:17 am
    I think I was able to track the problem. It seems that the second hdd makes AE crash.
    If I change the cache and move my project files to the primary drive which is the windows drive the issues seems to dissapear.
    I dont understand because the second disk should be ok, it is an seagate barracuda 1 tb.
    Could the disk be damaged in some way , and cause these strange shutdowns in AE?
