Activity › Forums › Adobe After Effects › After Effects CS5 Renders are choppy and file is HUGEE!!
Posted by Jay Toss on August 17, 2011 at 4:47 amWould love some help please !!! i know this is the place to get it
I looked but couldn’t find anything to help me !So my renders are choppy and not smooth!!
This is what i got
-3 minute video with animation and .mov file videos
-The competition frame rate is 25.. i dont know if thats good or bad?
-The video is 1920 by 1080I rendered
H.264 – 120 bitrate – Highest bit rate for audio
Now i got a file that’s 2.33 GB BIG!!! in MP4 AND CHOOPPPYYYY ERRRR
Can someone please please please help!!
I need the best Quality setting ever and this video is being used for youtube.
Thanks for the help 🙂
Jay Toss replied 15 years ago 4 Members · 12 Replies -
Todd Kopriva
August 17, 2011 at 6:16 am“FAQ: Why is my output file huge, and why doesn’t it play back smoothly in a media player?
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Kevin Camp
August 17, 2011 at 2:48 pm[jay Toss] “-The competition frame rate is 25.. i dont know if thats good or bad?”
25fps is the standard for europe, but would be just fine for web… good or bad would depend if you had footage in the comp. if you had footage in the comp, then it’d generally best to have the comp match the footage frame rate.
however, if you had footage that was higher than 30fps and the destination was youtube/web, you might want to set it at half the footage frame rate.
[jay Toss] “-The video is 1920 by 1080”
youtube hd is 1280×720, so you don’t need to render larger than that for youtube. at this point you could just drop your current 1080 comp into a new 720 comp (same durations and frame rate). then, with that comp layer selected in the new 720 comp, choose layer>transform>fit-to-comp to resize it to 720.
after that, you should render as a quicktime lossless animation file. this file will be huge, but you’ll take that to a compression utility like adobe’s media encoder. if you use media encoder, just set the format to h.264 and the preset to youtube widescreen hd. for better output, click the preset name, go to the video tab and set bitrate encoding to vbr, 2 pass…. also, make sure that the frame rate matches your render’s frame rate.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Jay Toss
August 17, 2011 at 8:07 pmThank you soooooo much Kevin Camp for the reply!!!!
SO i checked my Footage and its 29 for the Frame-rate.. So im going to change the 25 in the comp to 29!
As for you-tube.. I’ll do exactly what you said! i just thought if i re-size it, i will lose detail etc?? But ill take my 1080 comp, put it in the new 1280/780 comp – re-size and do you’re render settings !
I hope this all works. thanks again
I let you know what happens!
Jay
Michael Szalapski
August 17, 2011 at 8:17 pmActually, YouTube does go up to 1920×1080. In fact, it can go up to 4K (for some unknown reason).
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Jay Toss
August 17, 2011 at 8:27 pmReally?? so no resize..? keep it at 1920/1080 ??? just do Kevin Camp render settings?
Kevin Camp
August 17, 2011 at 8:45 pm1080 now… sorry i didn’t know.
however, if you want to keep 1080, you’ll need to modify the media encoder preset to be 1080. i think it is preset to 720 (though maybe adobe has added a 1080 preset).
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Jay Toss
August 17, 2011 at 9:31 pm“1080 now… sorry i didn’t know.
however, if you want to keep 1080, you’ll need to modify the media encoder preset to be 1080. i think it is preset to 720 (though maybe adobe has added a 1080 preset).”
Ok i was going to use the adobe encoder, but would it be hard to modify the preset to be 1080? or should i use something else
Thanks for all the help !!
Kevin Camp
August 17, 2011 at 10:33 pmit’s easy… just like changing from 1-pass to 2-pass encode, choose the youtube hd preset, click the name and then find the frame size, it’s probably one of the first options under the video tab… set it to 1920×1080.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Jay Toss
August 18, 2011 at 6:44 amSo im stuck on changing the Frames per second!?
Going from 25 to 29
All the audio changes pitch??! ( the demon sound )
And i dont know if its just the demon sound making the footage seem slower???I tried changing the FPS in the same project comp. that didnt work.
then i took the whole project comp and put it into a new comp with 29fpsthat didnt work!!! ERR$*@%&%*
What am i doing wrong???
