Activity Forums Adobe After Effects After Effects CS5 lighting after rotoscoping
  • After Effects CS5 lighting after rotoscoping
    Posted by Daniel Snyder on January 6, 2013 at 8:42 pm
    I am doing a project that required me to rotoscope out a computer encasing from the rest of the video it was a part of to change the background to a flat white background. I have done so but now I am need to add some extra lighting on the computer casing because it is to dark against the white background. First, is this even possible? If it is how do I do it? I have tried adding a light but it seems to only affect the white background I have added.
    Any help is greatly appreciated!
    D
    Daniel Snyder replied 13 years, 8 months ago 3 Members · 3 Replies
  • Herbie Humperdink
    January 6, 2013 at 9:25 pm
    You probably need to add some sort of light wrap. Here is how I do it, you need to first duplicate your layer :
    1- Make sure you precomp the layer on top
    2- Apply a blur
    3- Inver Alpha
    4- Fill with color white (because your background is white)
    5- Apply a CC composite and set to stencil alpha (or silouette, I always forget which is the one)
    6- Set it to add or screen
    Let me know if this makes sense
  • Darby Edelen
    January 6, 2013 at 9:30 pm
    Lights only affect 3D layers that have their “Accepts Lights” property set to ‘On.’ Once your layer is a 3D layer you can press ‘aa’ to reveal the material options where this property resides.
    However, you might consider using color correction effects to lighten up your footage instead. These are generally better for changing the overall look of footage. Read up on the Color Correction > Levels or Color Correction > Curves effect.
    Darby Edelen
  • Daniel Snyder
    January 6, 2013 at 10:26 pm
    Thank You! This is a much easier process then working with a light in After Effects. You have saved me so much time.
