Activity Forums Adobe After Effects After Effects CS5 Larger-Format Rendering Issues
  • After Effects CS5 Larger-Format Rendering Issues
    Posted by Stephen Rutherford on September 20, 2010 at 9:02 pm
    I am having issues with my render output from AE CS5… I work with live event video screens, some with really crazy resolutions (fascia boards).
    The largest resolution screen that we have is 13,194 pixels wide. Historically, I have been able to render with no troubles. However, with CS5, the larger-width renders are getting messed up. The first 2500 pixels or so are good (from the left-hand side), but then it starts distorting as the image goes farther left.
    Any ideas as to why something like this would happen?
    Stephen Rutherford
    Graphics Producer: Gale Force Media, CanesVision & Wolfpack TV
    stephenr@carolinahurricanes.com
    https://www.facebook.com/swrutherford
    https://www.twitter.com/CVHD
    CAROLINA HURRICANES: 2006 STANLEY CUP CHAMPIONS!
    Current System Configuration:
    Intel i7 920 PC 2.67 GHz
    Windows Vista Ultimate 64 Bit
    12 GB DDR3 RAM
    NVIDIA GeForceGTS 250 512MB DDR3
    Adobe Production Premium CS4
    3D Studio Max 2010
    Stephen Rutherford replied 15 years, 7 months ago 5 Members · 12 Replies
  • 12 Replies
  • Walter Soyka
    September 20, 2010 at 9:07 pm
    [Stephen Rutherford] “The largest resolution screen that we have is 13,194 pixels wide. Historically, I have been able to render with no troubles. However, with CS5, the larger-width renders are getting messed up. The first 2500 pixels or so are good (from the left-hand side), but then it starts distorting as the image goes farther left.”
    A couple questions:
    Where precisely does the distortion start? Does it happen to be after 2560 pixels?
    Have you updated to AE 10.0.1? It fixes a lot of bugs.
    Are you rendering with OpenGL? If so, what happens if you disable it?
    What format are you rendering to? Have you tried rendering to an image sequence?
    Walter Soyka
  • Stephen Rutherford
    September 20, 2010 at 10:15 pm
    I actually didn’t realize that OpenGL was a setting for final rendering; I thought it was only for previews…
    Either way, it’s off now 🙂 Unfortunately, it didn’t solve the render issue.
    I am attempting to render Lossless, which is an uncompressed .avi on my platform…
    The distortion begins at pixel 4048 and happens again at 8096 & 12144 (each 4048 apart…)
    On the render output window, there is a warning message at the bottom of the output module settings that says there is a settings mismatch…
    Clicking the warning icon gives the following dialog box….
    Perhaps this is part of the issue? I do not WANT to re-size to 32 pixels tall, because the board is only 24 tall…
    Just because it doesn’t make sense doesn’t mean it’s not correct 😉
    Is there a way to bypass this error?
    Thanks for the prompt replies!
    Stephen Rutherford
    12 GB DDR3 RAM
    3D Studio Max 2010
  • Walter Soyka
    September 20, 2010 at 11:52 pm
    I’d try rendering out to an image sequence to see if that renders undistorted. This will help us figure out where the problem lies.
    Image rasters larger than 4K seems to be a problem for some containers and codecs. How do you actually deliver to the media server that feeds the board?
    Walter Soyka
  • Todd Kopriva
    September 21, 2010 at 6:45 am
    Here’s a thread where Tim Kurkoski (After Effects quality engineer) and I explain the output constraints in After Effects CS5 to someone with a very similar issue to what you’re facing:
    https://forums.adobe.com/message/2972883
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
    September 21, 2010 at 2:17 pm
    @Todd: Thank you for the link. This is precisely my issue. Our stadium has various sizes of LED fascia boards from 13,194×24 down to 32×896. Obviously, the 32’s aren’t a problem…
    @Walter: As for delivery, I am networked to the computers that host the files and play them back. I have historically rendered the .avi straight through the network onto the computer that will host the file and am then able to play the file back with no issues.
    Under the tight deadlines that we work under, it has always been advantageous for me to be able to render the uncompressed .avi as it is the final file type needed for playback. Rendering intermediate stills or Quicktime files to be “flipped” later just adds time I do not have.
    Unfortunately, I can not get into too much detail today, as we have a pre-season hockey game tonight; our first of the year. I will try to update tomorrow with more information about my workflow.
    I do appreciate the follow ups, especially from those who know the back-stage parts of the program that I’ve grown to love over the years 🙂
    Stephen Rutherford
    12 GB DDR3 RAM
    Adobe Production Premium CS5/CS4/CS3
    3D Studio Max 2011/2010/2009
    September 21, 2010 at 2:34 pm
    I just tried the image sequence trick. It did work.
    I rendered the 13,194 x 24 file to a PhotoShop Sequence in the Render Queue, then brought that into the V7000 Sequence Designer program (we’re using Daktronics video boards) and imported the .psd into the proprietary “sequence” file that the V7000 Display program can use.
    Sorry for the brand names, it’s just easier to speak in specifics.
    It was a single frame image, but worked fine. For animated files, I’m not sure if the Sequence Designer can take multiple frames and compile them into a single sequence… That will be on my end, though…
    If I was reading the forum correctly, Quicktime should be able to output the necessary file type, correct? If so, I do have a file-flipping program that I can use if necessary.
    Thankfully, I do still have CS4 on my machine, so I’m not completely dead in the water. I will just need to determine which projects need the .avi utilization and ust CS4 to render these projects.
    For arena/stadium content producers everywhere, can we please look at addressing this as either an update, patch or something for CS6?
    Stephen Rutherford
    12 GB DDR3 RAM
    September 21, 2010 at 4:19 pm
    Daktronics has a little different meaning to “sequence” than does After Effects. It’s difficult for the V7000 program to ingest multiple images quickly (i.e.–jpg sequence, tga sequence, bmp sequence…).
    It can, however, dissect an .avi and put it into it’s own .SQ7 file type, sequencing “frames” every 1/30th of a second… Again, that will be an issue I need to work through on my end…
    I’m just trying to get the full story on the .avi output from CS5 for now 🙂
    Stephen Rutherford
    12 GB DDR3 RAM
  • Gary Hazen
    September 21, 2010 at 5:35 pm
    I would use the QT render > AVI conversion workaround. Sure, it stinks that you have to use a workaround because of the 32 pixel restriction. But it beats the heck out of using DAK’s clunky sequence designer.
    I hope Adobe fixes the size restriction with the next version. The use of LED facia boards is expanding well beyond stadium use.
  • Todd Kopriva
    September 21, 2010 at 5:40 pm
    This conversation and the one on the Adobe forum that I pointed you to are making it pretty clear that we need to consider this LED display workflow and its requirement for AVI files with smaller dimenstions. I won’t make any specific promises about specific future versions, but I will tell you that this is on our radar. Thanks for being so detailed and patient in explaining the workflow so that we know what needs to be done.
    If you want to make absolutely sure, you can file a bug-report/feature-request explaining exactly what you need to have changed
    September 21, 2010 at 5:43 pm
    Dak’s design and display tools are clunky, for sure! It’s just what we have to work with 🙂
    I certainly appreciate all of the responses. It helps me realize that I’m not going 100% insane here 😉
    @Todd: I thank you for listening and offering assitance! You have helped me realize that Adobe is more than just a software manufacturer, but you are really concerned with the people who spend their lives working with your product. Thanks for listening!
    Stephen Rutherford
    12 GB DDR3 RAM
