Activity Forums Adobe After Effects after effects cs5 lag
  • after effects cs5 lag
    Posted by Keith Vickers on October 2, 2010 at 11:24 am
    I have recently purchased a new dell i7 with 6 gig ram. I am using After Effects cs5 and it is slow. Whenever I try to reposition objects like images other images on screen disappear.I have an image as a 3d layer and when I move it the screen goes blank.I started particle world and when I scrub the timeline my particles disappear then reappear when I stop.I know my machines specs are not that brilliant but surely cs5 should run quicker than this on a new laptop. I am thinking of going back to cs3 with my dual core machine.
    Do any members have suggestions?
    Keith Vickers replied 15 years, 11 months ago 5 Members · 6 Replies
  • David Johnson
    October 2, 2010 at 9:25 pm
    I don’t have the specs for a Dell i7 memorized and you didn’t mention anything else about your machine, but some of the first things to do:
    Turn off multiprocessing in AE (until you get more RAM)
    Turn off OpenGL in AE (forever)
    Close any other programs you might have running while working in AE (or forever … who needs anything other than AE? lol)
    Get more RAM
  • Andrew Devis
    October 3, 2010 at 10:52 am
    It sounds like a screen refresh issue to me and one I have had in the past. From memory the problem was solved when I updated my video card driver to the latest version and did a complete re-start.
    You may find this help file useful as well:
    https://help.adobe.com/en_US/aftereffects/cs/using/WSF13D6BED-C53B-408a-B2D6-C8B4205D4FB7a.html
    I run CS5 on a laptop with only 4G and it works fine, so don’t panic!
    Andrew
  • Todd Kopriva
    October 3, 2010 at 5:27 pm
    Actually, from the description of the issue, it seems that it’s not a performance issue at all but the fact that Keith turned Live Update off.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Scott Novasic
    October 4, 2010 at 10:53 pm
    more memory! 64 bit is all about the memory… invest in as much as you can afford and you will not regret it.
    Scott
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
  • Todd Kopriva
    October 4, 2010 at 11:15 pm
    I certainly agree with Scott, but please heed my post about Live Update. I’m pretty sure that this isn’t actually a thread about a performance problem… but that that is a red herring.
  • Keith Vickers
    October 7, 2010 at 10:02 am
    Thanks for the reply David. I will get on it right away. Thanks again.
