Activity Forums Adobe After Effects After Effects CS5 Footage turned invisible/not showing in composition preview!!
  • After Effects CS5 Footage turned invisible/not showing in composition preview!!
    Posted by Glenn l Smith on July 27, 2011 at 2:21 pm
    Hi all,
    I have been creating a special effects shootout video, using many different videos layered on-top of each other. Once composition I have is a grenade explosion. In this i have the background video of the actor diving, and then layered on top i have a keyed out explosion, then smoke effects, camera shake etc.
    I had finished this and all was well until on a new composition in the same project, and I had a look back at the grenade composition. I was surprised to find that all my hard work was not showing up!
    All the layers are all still there, the footage is all working in layer view, but yet when i watch it in the composition they do not show up! I can’t understand what has happened.
    Heres a few things to note;
    – I have not got the visibility turned off
    – The layered explosions and smoke are all .mov
    – It was working at one point not too long ago
    – I have many compositions in the same project
    – All the other effects in other compositions have not turned invisible
    – If i double click the layer and look at them in the layer window they are playing perfectly and are still there
    This took me a long time as I am just learning, please help as I don’t want to have to do it again!
    Murphy Thelen replied 11 years, 3 months ago 3 Members · 3 Replies
  • Walter Soyka
    July 27, 2011 at 2:44 pm
    Have you accidentally set the explosion as a guide layer [link]?
    If not, there are several other possible explanations, and a couple screen shots showing the precomp with the explosion and the UI as well as the main comp (with the invisible explosion) and the UI might help us help you.
    Walter Soyka
  • Glenn l Smith
    July 27, 2011 at 2:59 pm
    I think i have an idea what has caused it. I found the layers but they had been thrown wayy out of the composition window area on their own. Also they were kept in place with by tracking, but it seems that they no longer are.
    I have tracked on another composition and it seems that it has overwritten the track on this composition?
    Can you only track one composition per project or should it matter when it is done on different compositions but in the same project?
  • Murphy Thelen
    May 27, 2015 at 5:20 pm
    I had this issue and while I was not able to determine the cause, I did find a workaround.
    I created a new Comp, went into my old Comp and selected all layers, copied them, and then pasted them into my new Comp. Everything was then visible and in place.
    Hope this helps.
