Activity Forums Adobe After Effects After Effects CS5 Crashes
  • After Effects CS5 Crashes
    Posted by Seth Kessler on March 28, 2011 at 3:02 am
    Hello all!
    I’m a relatively inexperienced After Effect user but have, nonetheless, been working on a freelance job which requires my use of the program (CS5 version). I’ve been able to jump most of the hurdles involved with the associated learning curve but have ran into one which threatens the whole of this project (and my sanity!) Every time I try to render 5 seconds worth of animation the program up and crashes after the first frame is rendered. I’ve tried a number of different codecs, I turned off the multiple processing option and will continue to do trial and error but I wanted to see if anyone on this forum could lend a struggling novice some insight. My stage is composed of a number of flat items imported from illustrator and use very little color (mostly white and shades of green) as well as some vector masks. There are a number of 3-d layers (5-8). The stage itself is 1920×1080, square pixel and ive been mostly trying to render using Quicktime, animation codec. With no other programs running on my comp i have about 1.5 gigs devoted to AfterEffects (perhaps this is the problem? my mac can only handle 1 additional gig of memory–its at 3gigs now).
    Any help would be GREATLY APPRECIATED!! I just started to do freelance and, as this is my bread and butter, I really need these programs to be functional
    –thanks in advance 🙂
    Seth K.
    Chip Hess replied 15 years, 6 months ago 3 Members · 4 Replies
  • Anders Hattne
    March 28, 2011 at 10:10 am
    I find it better to render out image sequences because of crashes. Also if you have to replace a piece you just render out those frames.
    If it crashes every 5 frames.. it’s probably crazytalk, but why not try setting the “empty cache” option to every four frames?
    (In the secret menu holding shift when selecting the general preferences)
    If there’s a crash while rendering an image sequences generally a new job is made starting where the old one stopped.
    http://www.ardillamedia.com
  • Seth Kessler
    March 28, 2011 at 5:00 pm
    Thanks for your insight, I very much appreciate it! Looks like I’m going to need an upgrade 🙁
  • Seth Kessler
    March 28, 2011 at 5:05 pm
    Thanks for your tip, but the program continues to crash…Im going to have to upgrade my system it seems 🙁
  • Chip Hess
    March 29, 2011 at 9:30 pm
    Dave –
    I run a Quad core iMac, 8 GB RAM.
    I guess I should turn multiprocessing off, then?
    Interesting.
    What specs does using Open GL require?
