Activity › Forums › Adobe After Effects › After Effects ( CS5 ) and Final Cut Pro workflow questions
  • After Effects ( CS5 ) and Final Cut Pro workflow questions
    Posted by Petr Tomkevich on July 26, 2010 at 1:47 pm
    Hey everybody,
    I am trying to gain some knowledge on working with a project that requires some VFX from After Effects with the delivery being in Apple ProRes 422. I understand the workflow inside FCP completely and have a nearing deadline so I don’t have the time to learn Premiere even though I am planning on it. I never used FCP with AE and am only new to AE. Some questions here :
    When is the best time to export a sequence from FCP to AE? Can I do it anytime or is it not as seamless as Premiere?
    If I want to deliver in 4k through Color, when can I start meddling with the footage in AE?
    and…
    How do I export from FCP to AE and from AE to FCP?
    Petr
    Uli Plank replied 16 years, 2 months ago 3 Members · 3 Replies
  • Keith Mcgregor
    July 26, 2010 at 7:24 pm
    It will not be as seemless as in all adobe project connected by the dynamic link. There is something out there called automatic duck that people use. Read through this: https://www.creative-workflow-hacks.com/2006/03/09/moving-between-final-cut-pro-and-after-effects-the-scripting-option/
    Or if you have boris:https://www.borisfx.com/tutorials/XML-Transfer.php
    But when? That is kinda up to you. When I finish my edit I export just the shots to be affected with handles to a qt movie, mess it in AE and export in uncompressed (animation) and then relink in FCP. So I never bring in the entire timeline, and wouldn’t want to (if only a couple of shots are to be effected and not the whole thing, why waste time rendering to import and render again?) Then the finished edit goes to Color. Cheers!
    -Keith
    Reality? What did you make it?
  • Petr Tomkevich
    July 28, 2010 at 1:59 am
    Hey Keith,
    Never heard of Automatic Duck, I’ll give it a go. Very new to After Effects. I appreciate the help.
    Petr
  • Uli Plank
    July 29, 2010 at 9:08 am
    Try XMLs first, it might be OK for you:
    – export XMLs from FCP
    – load them into PPro
    – save the PPro project (I like this better than DL)
    – open in AEFX
    Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
