After Effects CS4 vs. After Effects Pro CS4: Difference?
Hi folks,
Anyone know the difference(s) between the Pro and regular versions of AE CS4? Specifically, I’m wondering if the regular version is limited with regards to the bit depth it can use for projects. I know 8 bit is common, and 16 bit is possible with the Pro version; but, is 16 bit also possible with the regular version?
Thanks very much.
Vic
