Activity Forums Adobe After Effects After Effects CS4 Trouble!
  • After Effects CS4 Trouble!
    Posted by Rhys Bowen on January 28, 2010 at 12:10 pm
    Hello, I have had this programme on my Laptop for a few months now, and it has been working fine. I had no memory on the laptop so I got an external hard drive and put loads!! of things on there so i could have more memory for After Effects, but after I did that, after effects went very very slow!!!!
    It is fast opening, adding things (effects, 3D…) but when I play it back in the Footage/Composition it takes forever to render just ONE frame.
    Then it goes through about 3/4 frames then it takes forever again.
    Please does anyone know anything I can do?
    I re-installed it but still having problems.
    I have an interview with college next week, and am trying to get some stuff done for it but i cant when it goes this slow. (I also put the Quality from High, to low but still does it.
    If I don’t reply on here please email me.
    Skrapi@live.co.uk
    Thanks everyone
    Rhys Bowen replied 16 years, 7 months ago 4 Members · 8 Replies
  • 8 Replies
  • Andy Dykstra
    January 28, 2010 at 4:03 pm
    After Effects is a pretty resource intense program. You’ll need at least a few gigs of RAM to really do anything. It sounds like you’re a little confused because adding an external hard drive will only give you more space to store files, it won’t make after effects run any faster. You can look into upgrading your RAM, but laptops are usually very limited in how much you can add.
    Your easiest solution is going to be setting your comp settings to be showing half or less of the project. Directly under your composition there is a drop down that says “full” and can be set to half, third, or quarter. Lower settings will help after effects refresh faster for you, but you will see a low resolution version. Your final render will still be full quality.
    http://www.ghostrender.com
  • Todd Kopriva
    January 28, 2010 at 4:15 pm
    We can’t help you if we don’t know the exact version numbers of After Effects (9.0.0, 9.0.2?) and your operating system, how much RAM you have, et cetera.
    In the meantime, here’s a link to a post that addresses the most common performance problem that I see: “Performance tip: Don’t starve your software of RAM”. There are a bunch of other performance tips here: “Improve performance”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Rhys Bowen
    January 28, 2010 at 4:30 pm
    Here is my laptop Spec:
    System Manufacturer: Acer
    System Model: Aspire 6935
    Motherboard Manufacturer: Acer
    Motherboard Model: Aspire 6935
    Here is it’s performace:
    Maximum Memory Capacity: 4194304 MB
    Currently Installed Memory: 3072 MB
    Available Memory Slots: N.A.
    Total Memory Slots: 2
    Dual Channel Support: N.A.
    CPU Manufacturer: GenuineIntel
    CPU Family: Intel(R) Core(TM)2 Duo CPU T6400 @ 2.00GHz Model 7, Stepping 10
    CPU Speed: 1200 MHz
    I am running Adobe After Effects CS4: Version 9.0
    I have 2 slots, one with 2Gb and one with 1Gb, I’m thinking about replacing the 1GB with a 2GB.
    Any suggestions? (?No harm in trying?)
  • John Cuevas
    January 28, 2010 at 7:53 pm
    Are you putting the source footage, graphics…on the external drive? That maybe slowing AE as it has to access the external drive to render the each frame. If that’s the case move the footage to the internal drive and see if that speeds up the program.
    Johnny Cuevas, Editor
    http://www.ckandco.net
  • Rhys Bowen
    January 28, 2010 at 8:24 pm
    The videos are imported from my Internal Memory, My external just holds all my videos that i got off my HD Camcorder as they are over 200MB, so I keep them just incase I loose the ones I converted with Sony Vegas down to 56Mb and use them in After Effects.
    I see what you are saying tho.
    Also I don’t have my External Hard Drive plugged in when I use AE.
  • John Cuevas
    January 28, 2010 at 9:01 pm
    I keep reading this and I’m wondering are you trying to play what you are working on in AE. If so, yes it can take some time—and depending on the effects, footage, resolution, maybe a lot of time.. AE really isn’t designed for much in playback. When I use it, I may RAM preview, 1 second to 5 seconds of an animation and I’m on a very powerful computer(designed from Adobes recommended specs built specifically for After Effects.
    For playback and your interview, you need to render the files an .avi, .wmv or .mov on your harddrive and play from there and now AE.
  • Rhys Bowen
    January 29, 2010 at 1:34 am
    Thanks mate, I will do that. most probably in Avi.
    Going to get an extra gig of RAM on my laptop and see if it helps if not it might speed up other things.
  • Rhys Bowen
