Activity › Forums › Adobe After Effects › After Effects CS4 Rendering – Skipping
  • After Effects CS4 Rendering – Skipping
    Posted by Evan Reid on June 5, 2010 at 8:27 am
    Hi there! I am a SUPER BEGINNER in After Effects and need some serious help. I have a project that is 1 1/2 minutes long. I have sent the final comp to the render queue several times and to File > Export several times. All 10-12 renderings I have finished wound up in HD quality (YAY!), but they all eiter skip and the music is completely off or the image is too slow for the music. I need help figuring out why they all do that and how I can get a great looking composition rendering without any skipping or “slowness”!
    Thanks in advance for any and all suggestions/comments!
    Steve Roberts replied 16 years, 3 months ago 2 Members · 7 Replies
  • 7 Replies
  • Steve Roberts
    June 5, 2010 at 2:21 pm
    You probably rendered to a very high quality and large size. Nice, but your computer’s drive is probably too slow to play it back smoothly.
    High-quality files are meant for transfer of files between applications for further processing. For smooth playback, you need to compress the files to get a smaller file size and thus lower data rate.
    What is your final deliverable?
    Who is it for?
    What machine is supposed to play it?
  • Evan Reid
    June 5, 2010 at 8:33 pm
    Well I don’t know what you mean by “final deliverable”, but the movie is intended to be an intro video for an event at my church. I want it to play on our overhead projector – a Dell PC (I don’t know its specs).
    I will try a lower quality video rendering and let you know how that goes. Thanks!
  • Steve Roberts
    June 7, 2010 at 1:04 pm
    The final deliverable is the thing you deliver to the client at the end of the job. It would be described as a DVD or a quicktime movie for laptop playback, for example.
    The projector is secondary. What is primary is the playback device for the movie: hard drive or DVD player?
  • Evan Reid
    June 8, 2010 at 12:42 am
    Well… The projector is hooked up to a Dell PC. I was hoping to play the video once saved to its hard-drive. I was going to play the video through a program called EasyWorship – plays ALL video files.
  • Evan Reid
    June 8, 2010 at 12:45 am
    Hi Dave! Actually, my situation is odd. I downloaded a complete AE project off a website and it is awesome. It comes with pre-rendered MOV footage and some audio. I’m not having trouble playing the MOV footage, its just the entire project won’t render out correctly. I have a Toshiba 64 bit laptop. What render settings/options do either you or Steve suggest?
    Remeber: I’M A BEGINNER! Talk to me in baby-steps. Sorry.
  • Evan Reid
    June 8, 2010 at 5:45 am
    Hey guys! I finally figured out the right settings to use. I just finished a rendering that looks BEAUTIFUL and matches up with my sound without any skipping. Here’s what I did:
    I sent my comp to the render queue. I changed the output mode to Quicktime Movie with a Photo-JPEG compression set at 94%. I checked on the audio output box as well. THAT’S IT!
    Thank you guys anyway for all of your encouraging advice.
    God bless!
    Evan
  • Steve Roberts
    June 8, 2010 at 4:05 pm
    Excellent.
