Activity Forums Adobe After Effects After Effects CS4 MAC to After Effects CS3 PC
  • After Effects CS4 MAC to After Effects CS3 PC
    Posted by Trent Whittington on October 27, 2009 at 1:32 am
    Hey COW’s.
    At the moment I am working with a different department in our college and we are having some problems sending them our After Effects files to work on.
    We are working with After Effects CS4 on Apple Computers and they are using After Effects CS3 on Windows. We can’t figure out how to share project files to each other.
    So my question to the great knowledge of the COW Is…
    1) How do we share project files from CS4 Mac to CS3 PC and back again?
    2) If this isn’t possible, what is the next best solution?
    Thanks. Much appreciated.
    Trent Whittington – Currently studying Associate Degree in Digital Television
    http://www.trentwhittington.com
    Philippe Lessard replied 16 years, 10 months ago 5 Members · 8 Replies
  • 8 Replies
  • Jason Benjamin
    October 27, 2009 at 2:10 am
    Unfortunately. THIS IS NOT POSSIBLE, you can go from CS3 to CS4 cross platform but you cant go backwards. I have run into that before and it sucks.
  • Trent Whittington
    October 27, 2009 at 2:14 am
    Thanks for your quick response. I have access to CS3 at my university. Do you think if I resaved the after effects files in CS3 that this would fix the problem?
  • David Johnson
    October 27, 2009 at 2:39 am
    Unlike some other Adobe software, you can’t save an AE project as an older version than the version you’re saving from … in other words, you can’t save your CS4 project as a CS3 project so the folks you’re trying to share project files with will have to upgrade to CS4 … although at this point it would make most sense for you both to wait for CS5 and upgrade to it at the same time.
    The cross-platform part is a non-issue from the Adobe software standpoint, but you’ll want to be careful to avoid font issues.
  • Trent Whittington
    October 27, 2009 at 3:20 am
    Thanks very much for the info. Is it possible to create an XML from CS4 to CS3 as a work around? Or is it just not possible no matter what you do to go from CS4 Mac to CS3 PC?
    Just want to make sure I’ve covered everything before I pass on the bad news.
    Thanks.
  • Theo Veltman
    October 27, 2009 at 4:08 am
    Hi David, Just as a side note to let you know, Adobe Encore isn’t cross platform compatible as I’ve lernt from experience but everything else is.
    The only solution to this I have found is to open a copy of both CS3 and CS4 on your machine. Load the project in CS4 and import the same footage you are using into CS3. Place the footage into timelines as you have in your CS4 project. now on each layer in CS4 press U to bring up keyframes, select them all then copy them go to CS3 and past them onto the same piece of footage (you will need to ad key frames for any attribute you’ve changed and not keyed or enter this manually). If the keyframe is on an effect it will also copy this if it’s available in CS3.
  • David Johnson
    October 27, 2009 at 11:39 am
    Thanks Theo. I hadn’t thought of every Adobe product so I shouldn’t have worded that so broadly.
  • Trent Whittington
    October 27, 2009 at 2:06 pm
    Thanks everyone for your input, much appreciated!
  • Philippe Lessard
    October 27, 2009 at 2:48 pm
    Our friends https://maltaannon.com/ are currently working on that, he already find a work around consisting in draging and droping the assets from cs4 project windows to cs3 project windows, so you better having cs3 on your mac!!! but still have some issue, just go and read for yourself.
    Hope this help
