Activity Forums Adobe After Effects After Effects CS4 crashes or freezes on export
  • After Effects CS4 crashes or freezes on export
    Posted by Charles Farley on September 29, 2009 at 5:28 pm
    I am running After Effects CS4. It has been an up and down road with me since I got CS4. Sometimes it seems to work perfect, exporting and rendering very high resolution clips. Well today I created a leader for my corporate videos, its HD but by no means the highest resolution piece I have tried to export. Whenever I do export one of 2 things happens, occasionally it crashes with AE looking for more memory, but usually it just freezes on a particular frame. For example the export is something like 700 frames, so it will freeze on 85 and just stay there like its still exporting with no progress. Any ideas? I am running a dual core processor 2.5ghz along with 4gb of ram on a Windows XP system. I should have enough ram and memory to get this clip out….
    Hicham Chahidi replied 9 years, 9 months ago 4 Members · 9 Replies
  • 9 Replies
  • Charles Farley
    September 29, 2009 at 7:10 pm
    Hello,
    I am not using open gl (confirmed in settings) the media I am working with is in QT format (.mov). Originally I wanted to export in QT again (AVID DNxHD CODEC) But I have since tried to export an AVI and still get the same freezing. Any other ideas? Is there anyway to render smaller parts to take the load of the ram?
  • Todd Kopriva
    September 29, 2009 at 7:32 pm
    Have you updated to After Effects CS4 (9.0.2), which fixed several problems, including some crashes?
    You can render and export a sequence of still images and then recombine these still images into a movie. It’s common to use a post-render action to take a still-image sequence and convert it to a movie in a container such as an .mov file. Or you can use QuickTime Pro to do that.
    You can also carve up a composition into several smaller time spans and render and export each of those separately if one section is giving you problems. Just yesterday, I pointed to a script for doing this.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Charles Farley
    September 29, 2009 at 8:55 pm
    I didnt update yet, it does appear that a certain section (somewhat graphically intensive) is what is giving me problems. Although it’s not crashing and asking for more memory, just freezing and hanging up on that spot. The same thing happened while trying to do an image sequence. I just don’t get it.
    BTW the video is none of those codecs either.
  • Todd Kopriva
    September 29, 2009 at 9:00 pm
    If you’re having problems With After Effects CS4 and haven’t updated to 9.0.2, then I can’t really help you. That update fixed a lot of problems, and I don’t want to waste my time chasing issues that have already been fixed in the available update.
  • Charles Farley
    September 29, 2009 at 9:30 pm
    I will update now and let you know what happens. Thanks
  • Charles Farley
    September 29, 2009 at 10:16 pm
    I updated to the newest version of CS4 and the problem still exists, it freezes on a frame and will not progress further (no error message) except when I try to export an Image Sequence, then I am getting an out of memory error.
  • Todd Kopriva
    September 30, 2009 at 11:55 pm
    You’ve already got Render Multiple Frames Simultaneously turned off, right?
    And RAM To Leave For Other Applications turned all the way down?
  • Karl-jason Mawdsley
    October 14, 2009 at 1:33 pm
    I have this same problem – I’ve tried all the solutions but still get the same – AE freezes wehnever I try to render that frame. There are not particular effects or keyframes on it that aren’t elsewhere in the comp – I am stumped
  • Hicham Chahidi
    November 14, 2016 at 1:13 pm
    Hi Dave,
    Thank you!! I had the same trouble with Ae rendering since a long time, it crash on some projects in the same frame, and I couldn’t find what was wrong. Your solution worked for me. After disabling Oper GL and multiprocessing everything is fine now..
    Thank you!!!!!!
    Royalty free music
    https://www.musicscreen.org
