Activity › Forums › Adobe After Effects › after effects cs4 and winodws 7 64bit
  • after effects cs4 and winodws 7 64bit
    Posted by Aqeel Sami on April 25, 2010 at 8:36 am
    I want to know how could i make sure that i installed after effects cs4 on windows 7 64bit correctly because windows 7 64bit can even accepts 32 bit softwares. how could i know that i did everthing correctly because i installed after effects and found it in program files (x86).moreover,i think that after effects which is installed on windows 7 64bit and the one installed on another windows xp 32 are the same but i heard that there is a noticable difference between them. thanks alot
    Todd Kopriva replied 16 years, 5 months ago 2 Members · 1 Reply
  • Todd Kopriva
    April 25, 2010 at 2:57 pm
    There is nothing wrong with what you describe. The Program Files (x86) directory is where 32-bit applications get installed on 64-bit Windows. After Effects CS4 is a 32-bit application.
    It’s the same application. What’s different is that the 64-bit OS can see and use more memory, and that allows After Effects to more effectively take advantage of Render Multiple Frames Simultaneously multiprocessing.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
