Activity › Forums › Adobe After Effects › After Effects CS3 with Premiere Pro CS5.5
Posted by Paddy Uglow on July 29, 2011 at 1:49 pmI’ve got the Adobe production premium CS3 installed (photoshop, after effects, premiere pro etc), but am looking into getting the standalone Premiere Pro CS5.5.
What’s my best way of working with AFX 3 and ppro 5.5 together? I tried the “dynamic link” thing and it wouldn’t work.
I’m something of a newbie on using AFX and Ppro together.
Thanks all
– PaddyTodd Kopriva replied 15 years, 2 months ago 3 Members · 4 Replies -
Greg Burrus
July 29, 2011 at 3:57 pmTo my understanding you can only use dynamic link when you install the production premium suite for the version you are working on. Not sure if this applies to 5 and 5.5 but having a standalone won’t allow the dynamic link to work. Not sure if there would be a work around for this either since it is a core component. You maybe be able to import the project but it wont be “dynamic”.
Just my thoughts thoughts
Greg
https://mogra.g2bproductions.com/ – Blog
https://g2bproductions.com/ – Portfolio -
Todd Kopriva
July 29, 2011 at 8:52 pmDynamic Link only works between applications with the same version number (e.g., CS5.5 with CS5.5), and only when installed as part of a suite.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Paddy Uglow
August 1, 2011 at 9:35 amSo, if I’ve got something in P-pro CS5.5 that I want to add some effects to, I export that clip as Pro-res or AIC, open it in AFX, do my stuff, export it to a movie of the same codec/size, then import that onto my p-pro timeline?
Or is there a better way of doing it? I haven’t yet got the hang of the premiere-AFX workflow really.
Thanks for your time– Paddy
Todd Kopriva
August 1, 2011 at 3:29 pm> So, if I’ve got something in P-pro CS5.5 that I want to add some effects to, I export that clip as Pro-res or AIC, open it in AFX, do my stuff, export it to a movie of the same codec/size, then import that onto my p-pro timeline?
Yes, but don’t use either of the codecs that you just mentioned. They are both lossy codecs. Use a lossless codec for intermediate files. People often use the Animation or PNG codec in a QuickTime container for that purpose.
