Activity Forums Adobe After Effects After Effects CS3 Freeze frame problem
  • After Effects CS3 Freeze frame problem
    Posted by Patrick Saad on December 24, 2008 at 11:20 pm
    Hi everyone,
    I am having a weird problem with After Effects lately. Here’s 2 examples of the problem im having:
    Video Example 1:
    https://shorts.creativecow.net/film/121 at 1.24min (more then 3/4quarters of the movie)
    Video Example 2:
    https://shorts.creativecow.net/film/test-2-aefreeze-frame at 1.24min as well
    Here it is…
    I started working on a movie trailer where I imported other .mov movies, photoshop files, jpegs, and created some text animations, and added a soundtrack as well.
    After I completed most of my animation some of the footage that were on my timeline started freezing in certain areas of the timeline. When I would scrub over a layer with a footage for example that i had sliced the footage would not play correctly, instead of being able to scrub through the footage it would be a frozen frame of a random part of the footage layer. Even if I would insert into a new layer the same footage (unsplit, unedited) it would be frozen on the same exact frame as well. Once I render the composition, the same frozen frames would appear in the .mov file.
    I got confused, and couldn’t understand what the problem could be so I closed after effects, restarted osX and loaded the project file again, the next time around the same issue occured but with different layers and footage, it was constantly somewhat random… Its as if im running out of memory or something.
    But its not saying that I am… weird isnt it?
    I have my AE project file saved on my External HD 1TB LaCie and some of the footage and psds are on my MacBook HD which has 40GB left of space.
    Some of the footage i imported are quicktime .mov movie trailers I downloaded from the quicktime website with different sizes such as:
    h.264 codec 848×480 (HD 480P)
    AND
    h.264 codec 640×272 (Large format)
    Its causing this freeze frame over some of the psd layers as well, putting footage thats not even on that layer.
    I am using in AE, Max Mem Usage: 120%
    Enabled Disk Cache
    Max RAM Cache Size: 60%
    Max Disk Cache Size: 2000MB
    Stored on my External 1TB HD
    Here’s my macbook pro specs and after effects version:
    Model Name: MacBook Pro 15″
    Model Identifier: MacBookPro2,2
    Processor Name: Intel Core 2 Duo
    Processor Speed: 2.33 GHz
    Number Of Processors: 1
    Total Number Of Cores: 2
    L2 Cache: 4 MB
    Memory: 2 GB
    Bus Speed: 667 MHz
    Mac OS X: 10.5.5
    After Effects CS3 Professional:
    System: 10.5.5
    Quicktime: 7.5.5
    15% used of 2.0GB
    307 plugins
    Did anyone have a similar problem with AECS3 Pro before on their mac?
    Would appreciate any advice anyone can give.
    Thank you.
    Patrick S.
    Mort Bender replied 16 years, 11 months ago 4 Members · 9 Replies
  • 9 Replies
  • Jack Hilkewich
    December 25, 2008 at 9:15 am
    I think the problem is the fact that you have some files on an external HD that isn’t fast enough. Move all your files on to the main Hd in your computer and I think the problem will go away.
  • Patrick Saad
    December 25, 2008 at 7:22 pm
    It could be, but my hard drive is a LaCie 1TB Big Disk with Firewire 800 connected… could it be that its because its almost full, ( i have about 50GB left on it) ?
    I will give it a try and get back with the results.
    Thanks for your support Jack.
    Pat S.
  • Patrick Saad
    December 27, 2008 at 8:05 pm
    Hello Dave,
    Thanks for your feedback… I was actually going to do just that, and recompress the footage that i downloaded from quicktime.
    Do you have any compression settings you could suggest (using sorenson squeeze for example) to maintain the quality yet have a suitable format for editing in AE?
    I will get back to you if that solved the problem.
    Merci.
    Pat S.
  • Patrick Saad
    December 28, 2008 at 6:15 pm
    Hi Dave,
    I tried compressing all the h.264 movies to a LG quicktime format using sorenson squeeze but with no chances of success.
    Whats weird is that upon scrubbing through the time line and looking at the preview window, the freeze frame gradually occurs. That is, its not so much of a problem when i first start scrubbing(less frames frozen) but as I go through it over and over again, more frames start freezing all over the time line.
    Its as if im running out of memory. but when looking at the activity monitor on my mac I can see that i have lots of free memory lying around. I have 2GB of RAM and I was running no other application at that time except Google desktop.
    any clues?
    Thanks.
    Pat S.
  • Mort Bender
    April 16, 2009 at 4:51 pm
    I get the exact same thing.
    I am going mad… Seems like there is a few threads out there, all ends blind. No fix. I am doing my finals at Design College, if I do not get a fix, I do not graduate.
    Anyone know something please share…
  • Mort Bender
    April 16, 2009 at 5:39 pm
    * The project: simplify it! Break it into smaller projects if necessary! Prerender wherever you can!
    – Did that!
    * Footage: If the footage you imported into AE is any kind of the following — Native HDV, MPEG1, MPEG2, mp4, m2t, H.261 or H.264 — you need to convert it to a different codec. I’d use the Animation codec set to best quality.
    – Am using Animation Codec.
    * MP3 or AC3 audio: convert it to aiff or wav.
    – Have no MP3 or AC3.
    * Open GL: don’t use it under ANY circumstances. Just turn it off.
    – Is turned off.
    * If you’ve enabled the Disk Cache, DISABLE it… especially if you’re doing everything off one disk drive.
    – Is disabled.
    * Use AE default for memory usage (Max Mem Usage: 120%)
    – I do.
    * Turn off multiprocessing
    – Not sure what this is?
    * Set AE to purge every x number of frames. I’m not in front of my AE machine, and I can’t remember exactly where to find the command. I THINK you hold down the shift key and navigate to preferences. You could always consult AE Help (https://help.adobe.com/en_US/AfterEffects/9.0/) for a straighter answer.
    And not sure what this is either.
    Could you please explain further?
    Thanks for your answers.
    I am currently trouble shooting QuickTime codecs. Not sure if that will produce a result, but I am trying.
  • Mort Bender
    April 16, 2009 at 6:58 pm
    Here is a more detailed description:
    After Effects freezes my frames, not the same one each time, but randomly. Have noticed that it occurs when scrubbing back and forth. Then I can reload the project and earn a few seconds of working time, before the issue begins again, I can provoke it by scrubbing back and forth.
    Even when rendering out the problem occurs. Sometimes it jumps between 2-3 random frames, then when I scrub – to another layer, a random frame from that layer shows up, frozen though. I use some (not a lot) plugins; keying, and color correction, as well as track mattes, and I have some pre-comping going on. I currently have 58 layers, of which about 15 i precomps. Here is the major puzzle. ONLY the footage freezes, my animated graphic elements (Illustrator) keeps going just fine, as does the sound from the freezing footage – the sounds continues perfectly along with animation. I have done larger projects with no problem on the same machines, so I do not think that RAM or processing power is an issue. I use footage 1024×756, 25 fps (PAL I am in europe. Original footage is Mini DV), exported in Animation codec, audio 48.000, 16 bit.
  • Ryan Maloney
    October 8, 2009 at 5:13 am
    I am having this same problem. Did the quicktime codecs work out? Any solutions?
    I’m using Quicktime 7.5.5 and AE CS3 and have gone through everything in this thread to try and solve this prob, still no luck
    Thanks for any new info
    Ryan
  • Mort Bender
    October 8, 2009 at 7:26 am
    Hi Ryan!
    I never found out what caused the problem. But I finished my project in CS4, and I never had any problems again.
    So I am afraid that it is a CS3 problem, that arises under very certain circumstances – I am sorry I cannot be more helpful than that.
