Activity › Forums › Adobe After Effects › after effects CS3
  • after effects CS3
    Posted by Rudy Van sinten on September 9, 2008 at 9:55 am
    Hello anyone,
    Howe can i create in 3D a series of stills (pictures) behind each other spaced and then placed in Z space with a nice curve to the right.
    Thanks in advanced
    Rudy
    Roland R. kahlenberg replied 18 years ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    September 9, 2008 at 7:49 pm
    this sounds like something you should be able to do without much trouble unless you’re not familiar with AE’s 3D space. It’s best to look at purchasing one of the COW’s Master Series DVDs.
    But to get you started, here’s what you can try.
    Place all of your images in a comp. Make them 3D layers. With the layers still selected, press ‘P’ to display their position properties. Then offset their z-position in increments of 100 pixels so that they are laid out in z-space. Ensure that you also view your comp in Custom View so that you can have a better view of what’s happening to the layers.
    Once they are laid out nicely in z-space, you’ll then need to offset their x-position. Do likewise to the x-position of the layers as you did to their z-positions, ie. offset each layer’s x-position parameter by 100 pixels.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
