Activity Forums Adobe After Effects After Effects CS 5 crashes when bcc 3d objects extruded eps filter is applied
  • After Effects CS 5 crashes when bcc 3d objects extruded eps filter is applied
    Posted by Tim Vanbrackle on August 27, 2012 at 3:35 am
    Hello,
    I just installed a trial version (and an update) bcc continuum 8.1 for after effects cs5. everytime i apply the extruded eps filter, it just hangs. I am running mac 10.6.8 I am Opening illustrator files that work on cs5 and this system and I also converted to illustrator 8
    I don’t use illustrator, so i could be some simple button , but i don’t have a clue ????
    Any recommendations or help would be appreciated,
    Thanks Tim
    Tim Vanbrackle replied 14 years ago 1 Member · 0 Replies
  • 0 Replies
