Activity › Forums › Adobe After Effects › after effects crashing like it was its job
  • after effects crashing like it was its job
    Posted by Anonymous on October 23, 2005 at 5:25 am
    Ok I can barely work for a minute in AE with out having it crash. There seems to be no relation between the things that make it crash. I tried uninstalling and reinstalling AE to no avail. I have a project due this friday and I am on the verge of doing a fresh install of windows in hopes to fix the problem. The problem started occuring immediately after I installed a demo of trapcode’s Echospace. I tried uninstalling it but it didn’t help. I know this is a pretty vague post but if anyone had any suggestions I’m all ears.
    Anonymous replied 20 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Anonymous
    October 23, 2005 at 5:41 am
    ok Its late, I moved all my plugins and fired up AE. No problems. So it seems as if there is a plugin somewhere giving me the headache. Just gotta sift through and find the bad plugin and I should be good.
  • J. Chappell
    October 24, 2005 at 1:20 am
    If you find the solution please repost. I am having serious problem with AE6.5 crashing, especially if I try to move a layer on the timeline. The only change I have made to my workstation is loading the latest version of iTunes. (When I updated iTunes it gave a warning, “You will have to reorder QuicktimePro”
  • J. Chappell
    October 24, 2005 at 1:41 am
    I see a post from earlier today where someone else had a simular problem after loading iTunes 6 (I loaded iTunes 5 which also installs Quicktime7). That must be my problem also because I have never had any problems with AE6.5 before now!
  • Neil Harris
    October 24, 2005 at 1:59 pm
    Jo – how did you uninstall Echospace?
    anything more than just throwing the plug in away??
    i ask cos i half installed and want to get rid of it all now (can’t help you with yr problem i’m afraid)
    neil
  • Rob Kahn
    October 24, 2005 at 2:17 pm
    Just a guess, but maybe the AE preferences files didn’t get cleaned. Check in your users files for the your after effects preferences. Delete it. After effects will create a new one next time you launch.
  • Anonymous
    October 24, 2005 at 10:42 pm
    hhmm I did install itunes.. I think.. But my problem was with a plugin. After doing a fresh install of all my plugins It seems to be working fine. Good luck man!
  • Anonymous
    October 26, 2005 at 12:36 am
    I think echo space has an uninstaller inthe plugins folder. But also yea I think I just threw it out.
