Activity › Forums › Adobe After Effects › After Effects Crashes when Rendering
  • After Effects Crashes when Rendering
    Posted by Bob Zen on September 28, 2008 at 10:20 pm
    Hi Guys!
    Thanks for your help on my last post – it helped loads!
    Now, hopfully you’ll be able to help again! 🙂
    The problem this time is that when rendering out, and only when rendering to Quick Time Movies, After Effects crashes and I am left with a useless half rendered project.
    I meet all the requirements for the program to run, and everything works perfectly except when I render out to Quick Time. Furhtermore, this problem is only recent, as I have rendered many projects out before without this occuring. I have done all the usual proceedures to try and prevent this (ie restart program, computer, reinstall etc.) and it still doesn’t work.
    Any help is most appreciated!!
    Vicky xx
    Ola Pettersson replied 16 years, 11 months ago 4 Members · 5 Replies
  • Mark
    September 28, 2008 at 11:47 pm
    Have you updated quicktime recently ???? Could be the culprit…. When was the last time it worked ???? you could always back up projects, then rollback to that time.
    Mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • Chris Wright
    September 29, 2008 at 7:23 am
    what happens if you try using quicktimeplayer’s export file? Does it still crash? That one test will answer about 20 questions.
  • Bob Zen
    September 29, 2008 at 9:57 am
    Hi again!
    I’ve tried both of your suggestions and it still doesn’t work! Any more ideas would be welcomed- as the deadline is Wednesday!!
    Thanks Vicky xx
  • Chris Wright
    September 30, 2008 at 8:50 pm
    “Quick Time Movies” You never said what codec you were trying to use. You may need to use another codec brand if quicktime is unfixable which means you can’t use quicktimeplayer’s export, only AE’s.
    adding effects may be pushing AE over the edge from your high mem settings. try the defaults so that there is room for your graphics buffer to complete the effects.
    max mem usage 120%
    max ram cache size 60%
  • Ola Pettersson
    October 27, 2009 at 8:35 pm
    Hi
    I have the same problem as Vicki…
    When I try to export my AE projekt to .mov, so crashes AE.
    What do I do?? plz help
    Regards opettersson
