Activity Forums Adobe After Effects After Effects Crashes When Opening Project
  • After Effects Crashes When Opening Project
    Posted by John Doe on March 7, 2019 at 2:47 am
    Hi again. I’ve been having an issue with another project. Whenever I try to open the project, AE freezes and crashes. I really don’t want to redo everything so any help is appreciated. I use CS6.
    I’ve tried:
    Restarting the computer
    Importing the Project
    Opening with Caps-Lock on
    Clearing cache
    Updating Drivers
    None of these worked.
    Richard Garabedain replied 7 years, 6 months ago 3 Members · 4 Replies
  • Anders Hattne
    March 7, 2019 at 10:15 am
    Hello,
    Try opening After Effects. Then go File>Open.
    When you select the project file, hold down SHIFT. That way the project will open without opening any Compositions.
    You can also use Caps Lock to open Comps, and turn off all layer visibilities.
    Then you can go through the project until you find the comp / layer that causes the crash.
    Sometimes I’ve had problems with certain keyframes on masks!!
    http://www.ardillamedia.com
  • John Doe
    March 7, 2019 at 9:33 pm
    This method doesn’t work. After Effects crashes before I even get to see the project. It crashes while loading, in other words.
  • Anders Hattne
    March 8, 2019 at 10:00 am
    …in that case.. How about opening one of your previous versions from the Auto-Save Folder before it started crashing?
  • Richard Garabedain
    March 8, 2019 at 5:07 pm
    have you tried closing after effects and then Opening the project directly from its save file? this sometimes helps
