Activity › Forums › Adobe After Effects › After effects crashes as soon as I open
Posted by Jim Holden on May 13, 2017 at 7:18 pmI have the newest version of After Effects, as soon as I open it, it instantly crashes. It never did this before. It says “After Effects CC 2017 has quit unexpectedly”. Please help!
Crash Log
https://pastebin.com/ptMEukxVLouis Robert replied 7 years, 7 months ago 4 Members · 3 Replies -
James Graham
May 15, 2017 at 12:36 pmI had a similar thing a while back so I just rolled back my version of after effects to the previous one and carried on as before. Personally I try to never update a working system unless theres a particular feature that I want in the latest update. in creative cloud interface theres a drop down for previous versions on the install button.
That should fix things hopefully.
Good luck
Kevin Camp
May 15, 2017 at 4:06 pmif it happens when you are just opening after effects (not opening a project), you might try reseting the preference file. Quit AE and then restart it holding Ctrl+Alt+Shift (Windows) or Command+Option+Shift (OS X). Clip OK at the prompt.
if it’s while opening a project, turn caps-lock on and try opening the project. if that works, hide all the layers that are visible in the open comp and then click the caps-lock. then, one-by-one re-enable the layers to try and find the layer(s) that is causing the issue crash. once you found that layer (or layers), see what’s different about that layer — it’s often a third-party effect, or possibly a media codec — then troubleshoot from there.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW -
Louis Robert
January 11, 2019 at 9:16 pmThank you so much for that, I just couldn’t open AE anymore and was freaking out! Your “Command+Option+Shift (OS X). Clip OK at the prompt.” saved my day.
