Activity Forums Adobe After Effects After Effects: Convert Audio To Keyframes with frequency?
  • After Effects: Convert Audio To Keyframes with frequency?
    Posted by Eric Reed on October 26, 2016 at 11:32 pm
    I would like to be able to convert an audio track to keyframes with a certain frequency specified. (E.G. 50 Hz). From what I’ve seen, this is not possible; however, I would like to confirm this.
    Eric
    Michael Szalapski replied 9 years, 10 months ago 3 Members · 4 Replies
  • Greg Gesch
    October 27, 2016 at 1:13 am
    Hi Erik. I’m not aware that you can do this with standard AE, however I suspect you may be able to do it with the RedGiant Soundkeys program in AE. Might be worth a look?
  • Eric Reed
    October 27, 2016 at 1:16 am
    I will try, thank you!
  • Greg Gesch
    October 27, 2016 at 1:17 am
  • Michael Szalapski
    October 27, 2016 at 2:58 pm
    If you edit the sound clip in something like Audition to isolate the frequencies you’d like AE to respond to (and save it as a different name), you can use the convert audio to keyframes feature inside AE to pull data from that new sound file.
    Granted, Sound Keys is a much faster way to do it, but if you don’t already have it and don’t want to spend money, you can still do it with native Adobe tools.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
