Activity Forums Apple Final Cut Pro Legacy After Effects conversion
  • After Effects conversion
    Posted by Wally on May 28, 2007 at 11:00 pm
    I composed an intro in After Effects 6.5 using several layers (about 10 seconds long). When I imported it into FCP (in animation) it worked fine in the editing window but once I put it on the time line it stuttered and skipped several frames at the same point each time. I’ve tried piecing it together but it just doesn’t look right. What gives?
    Thank you for you anticipated response.
    Wally
    John Pale replied 19 years, 3 months ago 3 Members · 2 Replies
  • Wes Plate
    May 28, 2007 at 11:53 pm
    When you say “in animation” I assume that means you rendered to the Animation codec.
    How about rendering from AE to the codec of your FCP sequence? DV, for example, if you have a DV setup.
    — Wes Plate
    Automatic Duck
  • John Pale
    May 29, 2007 at 12:41 am
    did you render?
