Activity Forums Adobe After Effects After Effects constant crash
  • After Effects constant crash
    Posted by Francesco Capone on August 25, 2008 at 12:39 pm
    hi guys,
    i have a really big problem with AE 8.0.2
    I’m using it on a powerful machine,
    Mac Pro
    Quad-Core Intel Xeon 2.8 GHz, 2 processors, 8 cores, 12Mb L2 Cache, 32Gb RAM
    osX version is 10.5.4
    The problem is quite simple, AE just crashes everytime! when i scale movies, scrub the timeline and simple things like this.
    I don’t really know what to do! I had the same problems on other computer with similar configuration, but for example on my macbook pro with tiger works perfectly.
    Anyone knows something?
    I also tried the OpenGl Plugin trick but it didn’t work!
    Thank u!
    Francesco Capone replied 18 years, 1 month ago 2 Members · 2 Replies
  • Matthew Woods
    August 25, 2008 at 5:49 pm
    What resolution is your composition? AE CS3 crashes all over the place with multiprocessing and more than 6 processors if the composition resolution is above 2k. See this article:
    https://kb.adobe.com/selfservice/viewContent.do?externalId=kb402403&sliceId=2
    Depending on how often you work 2k or above, it might be worth following the instructions to restrict the number of render processes to 6.
    I normally work in 1280×720, so I haven’t done this and don’t normally have a problem, but I run in to trouble and have to disable multiprocessing when I occasionally do have to work with something larger…. it sucks and I hope they fix this soon.
    -Matt
  • Francesco Capone
    August 26, 2008 at 8:43 am
    thank you, i’m gonna try right now.
    I worked on quite big compositions but i have the same problem also on a 720×28
    It seems to me that is some kind of codec problem.
    If i work with the caps lock on so that i can’t see the videos, After Effects works perfectly.
    It only crashes in processes that involves video visualization or manipulation.
    For example: if I scale a layer with the caps lock OFF it crashes; caps lock ON no crash.
    Move layers with CL OFF -> crash; CL ON -> no crash.
    what can it be? I have quicktime 7.5, not the notoriusly bugged 7.4.
    Maybe I have to uninstall all the softwares like MPEGStreamclip, Cleaner XL or stuff like this?
    Ty guys
