Activity Forums Adobe After Effects After effects compositions showing a weird cross
  • After effects compositions showing a weird cross
    Posted by Aakash Chopra on January 24, 2021 at 12:56 pm
    A couple of compositions in my project have started to show up a weird cross on screen. I can’t figure out what it is.It even shows up in render. I have tried to switch on off layer but it is showing up on every layer. Anyone knows the problem??
    Walter Soyka replied 5 years, 7 months ago 3 Members · 3 Replies
  • Graham Quince
    January 24, 2021 at 1:09 pm
    One of the plugins you’re using in the comp is not registered. It’s an anti-piracy measure. You should just need to re-register the plug-in and restart AE and you should be good to go.
  • Aakash Chopra
    January 24, 2021 at 1:15 pm
    but it’s even showing in the composition where no plugin is used…
    Also the problem is in just one project.
  • Walter Soyka
    January 24, 2021 at 4:00 pm
    Try clearing your cache.
    Edit > Purge > All memory and disk cache
