Activity › Forums › Adobe After Effects › after effects composition sizing : how does it all work?
  • after effects composition sizing : how does it all work?
    Posted by Blake Warner on September 12, 2014 at 7:17 pm
    I have learned from watching several tutorials that 1920 X 1080 is the ideal dimensions for composition size in after effects. I was wondering if its the ratio that is most important and if so would it be alright to create a composition that is smaller while still being optimized for being displayed in video format on the web. The reason is because 1920 X 1080 is pretty large and the images I need for the video are not quite large enough to fill out the composition nicely when the dimensions are 1920 X 1080. I would very much appreciate some guidance.
    John Cuevas replied 12 years ago 3 Members · 2 Replies
  • Todd Kopriva
    September 12, 2014 at 10:11 pm
    That doesn’t by itself make sense.
    The right size for your composition depends on how you will be using the movie that you’re creating—i.e., what devices and/or software will be used to play the video.
    If, for example, you are creating a movie to be played full-frame on a high-definition television, then 1920×1080 makes sense.
    See this:
    https://helpx.adobe.com/after-effects/using/planning-setup.html
    After Effects team blog
  • John Cuevas
    September 13, 2014 at 2:22 pm
    If your video is going to the web, like Youtube or Vimeo, you could probably get away with 1280×720 that’s a smaller HD sized video.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
