Activity Forums Adobe After Effects After Effects Color Picker
  • After Effects Color Picker
    Posted by Chip Willis on January 23, 2012 at 9:47 pm
    Newbie on CC, and thanks for any heads up.
    I have been using After Effects for a while, but seems like my color picker is messed up when in 8bpc settings.
    I am used to having the right vertical display show the entire color spectrum and then the colors in the large window for selection being based on range by the right slider. Now, I do not see the entire range on the right vertical strip, and hunting for colors is a pain in the rump ( I want it to behave like photoshop which I am used to ). I understand if you change the color settings in the upper right pane info palette, it will change based on bit depth. Even if I set it at 8bpc, I can use the scrubber and get numbers well above 255 and below zero.
    Is this normal, I don’t remember it behaving like this before.
    Thanks in advance.
    Chip Willis
    Sid Olomi replied 12 years, 3 months ago 6 Members · 8 Replies
  • 8 Replies
  • Chip Willis
    January 23, 2012 at 10:08 pm
    Never mind, I figured it out.
  • Chip Willis
    January 23, 2012 at 10:11 pm
    never mind, I figured it out. Feel like a dork too 🙂
  • John Cuevas
    January 23, 2012 at 11:54 pm
    I’ve been using AE for 11 years and actually did the same thing with the color picker on Friday…and it took me an hour to figure out what I did.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Darryl Torke
    February 1, 2012 at 2:50 am
    So what is the answer, please?
  • Chip Willis
    February 1, 2012 at 3:49 am
    In the color picker, make sure the radio style button on H is clicked, then all will be normal. In the Hue, Sat, and Brightness section at top.
  • Jonathan Miller
    March 29, 2012 at 5:35 pm
    Whew! Thanks for this. I’ve been scratching my head for a day over this. I think my 18-month-old son clicked my mouse by accident and screwed the color picker up.
    It’s funny how disconcerting it is to have things not work properly in the software you live in every day!
    TreeLine Productions
    Fort Collins, CO USA
    Currently producing these popular podcasts:
    “The Rest of Everest” Video Podcast *Voted as one of iTunes’ “Best of 2006” & “Best of 2007 Classics” podcasts
    *Nominated for “Best Video Podcast” in the 2007 People’s Choice Podcast Awards
    http://www.therestofeverest.com
    “Beyond the Movement: The Pilates Podcast” http://www.thepilatespodcast.com
  • Sid Olomi
    March 15, 2013 at 4:56 pm
    hi i have the same problem but can not figure what are you talking about to fix the problem i don’t see this radio style button or H thing you are talking about can you be a bit spasifice plz
  • Jp Pelc
    May 28, 2014 at 9:03 pm
