Activity Forums Adobe After Effects After Effects CCSphere issue
  • After Effects CCSphere issue
    Posted by Radoman Radovic on July 5, 2017 at 11:32 am
    Hello there. I have an issue with CCSphere plugin. When I scale up radius of the sphere, it kind lowers the resolution. Also when I apply some wipe transision before CCSphere, to make sphere slices, edges become weird. I repeat, this is case only when I increase the sphere radius. Since CCSphere is not camera-aware plugin, can this issue be solved? Thanx in advance.
    Radoman Radovic replied 9 years, 2 months ago 1 Member · 1 Reply
  • Radoman Radovic
    July 5, 2017 at 2:27 pm
    I figured it out. DO NOT use solid, or shape to build CC Sphere on. Use simple high resolution *.ai Illustrator file with simple rectangle in it. Weird…
